dedicated wide slobber question. I know nothing about swing blade mills.
Started by Collima, July 21, 2015, 08:58:47 PM
Collima
I run a woodmizer lt70 super hydraulic.  But I recently bought a lucas DSM 23.  Apparently I can't run the planing attachment on it.  But couldn't I just buy the swing blade powerhead to run the planer attachment?
Woodmizer LT50, case SV250, lucas dsm23
dgdrls
Hi Collima,
Best to check with Left Coast supply.
From what I see the power-head and carriage are are not the
same from the DSM to the standard swingmill.
Best
DGDrls
You cant run a planer attachment because the engine on the dedicated slabber is fixed, can't slide across the log. You could mount a router on the carriage and slide that across as you run the carriage up and down the slab. Not as quick, but a much cheaper option.
47sawdust
Mick
JustinW_NZ
Quote from: 47sawdust on July 22, 2015, 05:31:56 AM
The widest slobber I ever saw was on a St.Bernard.
I did a pretty wide slobber on a big flitch once..  :D
Cheers
Justin
Gear I run;
addysdaddy
Nope, Newfoundland dog eating a cheezeburger... WOW :D, ... PS I wish I had your LT70 problem 8).. My LT10 is pretty jealous...  :D
Trying to think of something Cool to say kinda defeats the purpose.
LT10
Kioti with winch.
Husqvarna fan
terrifictimbersllc
sigidi
Yes mate, you can run the planer head on a swing blade carriage, but as you've found out, with the dedicated slabber the power head doesn't slide along the carriage, also I don't think it has a mounting plate off the driveshaft like the saw carriage does - hence why its a 'dedicated slabber' ;)
Grandedog
     Howdy,
   One of the reasons the planer disc doesn't work on the Dedicated Slabbing Mill is because of the rotation direction of the of the direct mounted DSM engine is opposite that of the Swingblade Mills that have gearboxes. The DSM23 runs on the 8" mill frame, so the smallest mill you could buy to work on the same frame as your DSM would be the Model 830 Powerhead Only, and the planning attachment. With this setup you have the widest versatility, and you would be really hard pressed to find piece wood it couldn't handle.
Regards
Gregg
Gregg Grande
Left Coast Supplies LLC
1615B South Main Street  Willits, CA 95490
888-995-7307  Ph 707-602-0141                   Fax 707-602-0134  Cell 707-354-3212
E-Mail  gregg@leftcoastsupplies.com   www.leftcoastsupplies.com
http://www.youtube.com/watch?v=nM2__SFWXE8
That's just a random Youtube clip, not my rig. But you get the idea. That would work on your existing DWS
This is my version.
sigidi
Gregg, down here the model 7 fits on with the 8 and 10, is it the same over there?
Grandedog
     Howdy,
   Yes, they would fit the same frame. We don't have any 7" models available here yet. They're still dicing out the EPA requirements.
Regards
Gregg
Gregg Grande
Grandedog
Gregg Grande
mesquite buckeye
If I ever get dedicated to slobberin' they better take away my chainsaw. :snowball:
deadfall
Quote from: mesquite buckeye on August 01, 2015, 10:28:59 PM
After I had exercised so much restraint.  It's so hard to leave a good straight line alone.    :D
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
mesquite buckeye
