Special Project Walnut Box or two!!
Started by Andy White, July 17, 2015, 03:19:02 PM
Andy White
Have an occasion to build a Walnut Keepsake box! Haven't done a jig cut thru dovetail in a while, and had to go to the book. After a little study, I prepped some pine for a test joint before cutting up this pretty Walnut!
After getting the setups dialed in on the jig, I got the side pieces for cutting the tails first, and started the process with the 7° dovetail bit.
Next was to install the straight bit and 5/8" bushing in router, and flip the finger plate on the jig.
This is a tedious process, so I cut all the tails first, then all the pins  for all boxes that I need  at one time.
Next is pick some pretty figured grain for the top, and for the bottom. Set up the router table, and cut a 1/4" deep rebate around the perimeter of the top and bottom for the sides to fit to when assembled.
Next take the edge profile bit and shape the top and bottom to suit the style.
Now the sanding and sealing grain and all the detail work to make this thing really smooth. After all finishing is done, I'll install hinges and get ready for another project!! :P :P smiley_smash smiley_smash  Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
WmFritz
Most excellent!
I like the contrast of the sapwood.
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
Brian_Weekley
Very nice.  I've only tried half-blind dovetails with my router jig--not through dovetails.  Looks like it worked quite well.
e aho laula
POSTON WIDEHEAD
Your work is amazing as always Andy. Keep it up.
Goat
Bill Gaiche
Nice Andy. At least you didn't use that hot cedar from Mississippi. bg
LUV2MILL
Andy White
Bill,
The hot Cedar from Mississippi has all been spoken for! I will saw three more logs, then build planters from the rest. That gator in Louisiana may let me get my other two logs now, if I need them. Lynn told me to come get some more if needed.
Lynn,
Yes you do!! That is some of that Boomerang Walnut. Looking back at the sawing pictures, I think it was the first one after the slab. The grain was really spectacular.     Andy
Ocklawahaboy
Beautiful work.
I was just given a Rockler version of that dovetail jig, along with a Craftsman Table saw, outfeed/work table etc.  Seeing your work makes me want to try it all out.
hackberry jake
I am envious of the dovetail joint... I have never moved past box joint. Dovetails definitely add some class.
Andy has a way of pushing the envelope.   smiley_thumbsup smiley_thumbsup
yukon cornelius
dovetails are certainly on my learn how to do list. they are just classy! also I like finger joints. hackberry jake had made some awesome crates or boxes with them.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
yukon cornelius
lowpolyjoe
LeeB
I bought a dovetail jig from someone on the forum years ago. It's still siting on the same shelf in the same spot where I put it down. Never tried it.
GAmillworker
Thank the Lord for second chances
Dan_Shade
I think dovetails are easier than finger joints.  tolerances cumulatively work against you with finger joints
lots of dull bands and chains
POSTON WIDEHEAD
I am glad to say I got to actually hold this box in my hands at the Pig Roast.
The details and wood grain is more beautiful in person than these pictures will ever show.
But, what Andy White's secret was during the entire building was that he was actually building two.  One as a door prize and another to be presented to Jeff & Tammy as a 35th Wedding Anniversary.  Go Andy !!!
Gadrock
when i grow up I want to be jus like my friend Andy White...but maybe a little bit lighter on my ladder.
david G
LT40 G18,   bent Cresent wrench,   broken timing light
Prentice 280 loader, Prentice 2432 skidder, Deere 643J fellerbuncher, Deere 648H skidder, Deere 650H Dozer
49er
Very nice box Andy. When I make a box with a lid I usually use a gold chain
as a stop for the lid. I have mixed feelings about doing it this way. I was wondering what supports the lid on your box when in the open position?
    I have been wanting to make my own wooden hinges on a box. I like the looks of them.
Husqvarna EC390 365xt
Jonsered 2188 2165 2260 2253 70e
Redmax GZ4000
Andy White
49er,
The lids have a rabbet around the bottom, and the hinge is morticed into the back. The rim of the lid stops against the back. That one would need a really small chain to look right with the size of the box. I built a large Cherry wood box and a Walnut box for things in the shop, and I used chain stops on them. They were much larger than these were.     Andy
