Completed Blade Sharpener
Started by LUV2MILL, July 16, 2015, 03:54:10 PM
LUV2MILL
I got the Cam ground welded reground welded etc. and now I think I'm finished I'm going to resharpen a couple of blades and try them.
http://www.youtube.com/watch?v=gy6C1TPnMbw
deadfall
Quote from: LUV2MILL on July 16, 2015, 03:54:10 PM
https://www.youtube.com/watch?v=1ME1BorbOoI
Quote from: YouTubeThis video contains content from Warner Chappel, who has blocked it in your country on copyright grounds.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
WmFritz
~Bill
2012 Homebuilt Bandmill
1959 Detroit built Ferguson TO35
deadfall
Quote from: WmFritz on July 16, 2015, 04:29:54 PM
That is a fine looking build.
That's what I wuz going to say, and ask how much he's selling them for, but then I got distracted when the video wuz unavailable.
LUV2MILL
Sorry about the video I'm reposting it without the background music give me few minutes.
Give that a try.
Den-Den
Good job on the sharpener, it looks great and appears to work as designed.  You should be proud of it.
One suggestion; consider adding a metal shield to deflect sparks and grit from entering the motor and ruining its bearings.
LUV2MILL
Quote from: Den-Den on July 16, 2015, 05:36:05 PM
Good point I'll work on that I also worked on the cam after this video to take the dip out of the gullet.
Thanks for the useful feedback and compliments.
hackberry jake
Excellent fit and finish as well. I need to get better at painting my metal projects. I usually leave them weld/rust colored.
boscojmb
John B.
Log-Master LM4
Luv2, very professionally done, what now a automatic setter.??  Frank C.
21incher
Great job! Thanks for sharing the video. How long does the grinding wheel last before it needs redressing?  :)
sandsawmill14
LUV2MILL
Not sure how long the dressing will last I'm sure it depends on how hard your grinding, I'm still playing around with the shape too much to know.
Automatic setter  ??? not sure more likely a manual double setter. If I do I'll post pictures.
hackberry jake
Quote from: bandmiller2 on July 16, 2015, 08:22:47 PM
I have some plans for one in the noggin... Just haven't had time to make it.
Kbeitz
Love machine shop work
and Wood work shop work
And now a saw mill work
LUV2MILL
Quote from: Kbeitz on July 16, 2015, 10:39:19 PM
Sure beats what I got....
I'd love to see that running those old machines are real art.
Kbeitz
 I got both that and this at the flea market...
LUV2MILL
Quote from: Kbeitz on July 17, 2015, 07:28:58 AM
I'd love to find some pieces like these to collect, all they seem to have at the flea markets around here is cheap import junk.
LUV2MILL
Den-Den wisely suggested a guard to protect the motor. After sharpening a couple of blades it was clear one was badly needed not just to protect the motor but to try to contain some of the mess as well.
WmFritz
When you get the blueprints drawn up, I want to be your first customer.  ;)
~Bill
Larry
Looks like a professional job to me.  Did you fabricate the spindle?
I'm slowing working on one.  Got all of the sub assemblies built, just need to get them put together.
LUV2MILL
Quote from: Larry on July 18, 2015, 03:59:09 PM
The spindle is a piece of 5/8" shaft with 1/4" key way already cut in it, I just turned the end down to just under 1/2" and threaded the end 1/2-13.
