Just Got My First Bill from a New Sawyer
Started by Glenn1, July 12, 2015, 10:36:27 PM
Seaman
Welcome to the FF Sawmillwife! I hope you find it a wonderful tool for your business as I do.
Lucas dedicated slabber
Woodmizer LT40HD
John Deere 5310 W/ FEL
Semper Fi
Peter Drouin
Quote from: Glenn1 on July 15, 2015, 09:16:14 PM
8'6" although I planned on trimming them to 8'.  I anchorsealed all the ends so I may just trim them straight and keep more lumber.
Trim when you use them for a job.
A&P saw Mill LLC.
License NH softwood grader.
sandsawmill14
welcome sawmillwife :)  sorry i forgot it earlier :-[
Finn1903
Welcome SawmillWife
The community here is great and great conversations on processing wood of all sorts.
WM LT40HDD47, bunch of saws, tractor, backhoe, and a loving wife.
Finn1903
Glenn,
As said earlier you should come out ahead with the cherry and walnut.
Another idea is to have the sweep cut through and through and leave the live edge.  not sure if that fit into your marketing plan, but give the end user some options.  Or to make a mantle piece.
Arkyrick
Just a quick question you mentioned cleaning the boards are you referring to cleaning off the sawdust from each cut board before stacking?
LT 35 hydraulic portable "73"Ford 335 tractor - lots of chains
Welcome to the Forestry Forum Arkyrick.
I carry a wide sheetrock knife for the customer to clean boards with and I also have wire brushes available.
deadfall
I keep a framing square by the mill for rotating logs backwards and squaring them up to the deck, so I can be sawing in through a clean side.  I find it is a great tool for taking off wet sawdust as well. I hate wet sawdust on my boards.
W-M LT40HD -- Siding Attachment -- Lathe-Mizer -- Ancient PTO Buzz Saw
Happy for no reason.
AnthonyW
Quote from: Magicman on July 16, 2015, 01:18:17 PM
The wire brush I understand. What's the sheetrock knife for?
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Maybe I should have said sheetrock taping knife.  They are an excellent tool used for scraping sawdust from boards.  ;D
deadfall
Oh, and a broom with a broken handle too.
YellowHammer
Quote from: Magicman on July 16, 2015, 02:40:40 PM
smiley_thumbsup smiley_thumbsup
Yes, they are very fast and do a good job, I like the 12 inch wide.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
4x4American
framing square works good too but its not "proper"
Boy, back in my day..
East ky logging
They who can give up essential liberty to obtain a little temporary safety deserve neither liberty or safety- Benjamin Franklin
deadfall
Quote from: 4x4American on July 17, 2015, 06:16:25 PM
But if you're left handed you can just flip it over.
Quote from: beenthere on July 14, 2015, 01:58:57 PM
The walnut and cherry boards member glenn1 was having sawn for him are likely not available at a Lowes...
If it was, it would be all dressed, clear and kilned for $6 bucks a running foot ($12/bf), 6" wide, 8' long. They want as much for a hardwood board in those places as a saw mill would give for a whole log (50 bf).  And I mean $900/th kind of logs, not junk. It's about $45 bucks here for a sugar maple board.   ;D :D
4x4American
Quote from: deadfall on July 17, 2015, 06:40:06 PM
unless you're using a metric square then you have to be right handed or ambidextrous
