replace lt 15 wheel bearings
Started by fred in montana, July 10, 2015, 07:23:12 AM
fred in montana
I realized that I have been over tensioning my blades for a long time and I think it shortened the life of my bandwheel bearings. I will have to replace them.
Did some searching but didn't find out everything I need to know to replace them.
I am thinking I need to remove the wheel/axle assembly from the mill then disassemble that to replace the bearings?
To remove the wheel axle assembly, I just loosen two of the four axle alignment bolts and drive the assembly forward and out using a hammer and a wooden block, striking the end of the axle?
Any pics/advice would be appreciated.
woodmizer lt15, mf 65 tractor
logdovetailjig.com
ladylake
 A good reason not to over tension to saw straight.  Steve
I would call WM and get a step by step procedure.
MartyParsons
Hello,
The idle side wheel would be quite simple to remove. Remove the center bolt 5/16". Remove the washer replace the bolt. Use a two or three jaw puller and remove the wheel. Most even just pull off with a little wiggle. There is a snap ring that holds the bearing in place. Remove the snap ring and use a press to remove the bearing and replace. Reverse procedure.
Drive side has a few more steps. You will need to remove the drive belt and the brake to get the wheel off. Other than that everything should be the same.
The reason you put the bolt back in the hole is to keep from damaging the bolt threads while using the puller. Ask me how I know this!  :-[
I have not seen any issues with these bearings.  Only mills with real high hours ( like 4 or 5 thousand) . Bearing failure may be due to leaving the band tension on when not in use or moisture getting in the bearing because the mill is not being used for sometime.   Just my opinion. Is there anymore to the story?
Bearing for idle side P08066  x 2  $ 10.61
Bearing for Drive side 014811 x 2 $12.12
These part # are for newer LT15 and LT28 and LT35.  I do think even the early LT15 use the same bearing. Check your manual.
Hope this helps.
Marty
drrivah
Trouble replacing drive belt on 18 mos old LT-15. No prior issues whatsoever: love this mill.javascript:load()
After removing through-bolt, cannot separate part (A, clutch pulley assembly, socket) from part (B, shaft to clutch handle).
Any suggestions before applying force or heat?
Thanks!
-pete barker
Ogham Hardwoods Milling
Loudoun County, Virginia
PC-Urban-Sawyer
drrivah
Welcome to the Forestry Forum
Looks like posting pics is giving you fits.
There are five in your gallery now, all alike.
So you can go to your gallery and clean out all but one. Then click on that one and it will enlarge. Right under that enlarged pic will be the instruction how to paste it into your post (have your post open in another window works best). Good luck with it, and shout out if there is a problem. Someone will help you out.
Second the Blue Creeper suggestion.. :)
Kbeitz
I made this tool for jobs like that...
Love machine shop work
and Wood work shop work
And now a saw mill work
Chuck White
Welcome to the Forestry Forum, drrivah.  (Pete)
MartyParsons
Hello,
You can tap the inside shaft ( 16)  toward the engine a little. # 18 should be supported by the flange on # 17  and come off easily. Watch the linkage on the engine side so it does not bind at # 11. You may need to remove the nut # 15 on the parts picture and let this ( 11) come out of the shaft ( 16) and drive it out of the bushings # 17. Relube the bushings (17) if they are dry when you replace the assembly.
Marty
valley ranch
