Clutch Slipping ??
Started by Magicman, July 07, 2015, 07:27:53 PM
That must be the problem because since if finished my Cabin Bedroom Project, I have been having trouble getting my butt in gear.
Sixacresand
This heat will definitely make your clutch slip.
luvmexfood
I call that the BIG problem. Can't get my Butt In Gear.
Give me a new saw chain and I can find you a rock in a heartbeat.
redprospector
I've found that if before I start in the morning, I put my butt in gear and then start with it already in gear I can go. It's a little hard on the starter though, and you have to be careful when shifting gears.  ;)
My get up and go has gone up and went.  ;D
About the time that you get your butt in gear you will be at the Pig Roast.
Good thought.  Three weeks.   8)
gspren
  I remember my Granddad claiming to have "Dropsy and heart failure", dropped his butt in the chair and don't have the heart to make it get up.
Hilltop366
You got to learn to park on a hill so you can get a rolling start. ;D
I started slowly and tapered off today.  Sawing tomorrow and a guy called this AM with a ~10Mbf framing lumber & wall paneling job.  (building a new home)
Holmes
  I prefer the " Start late and Quit early" option for work these days.  :)
Think like a farmer.
coxy
Quote from: Holmes on July 08, 2015, 03:58:42 PM
start at 3 quit at 305 or is 305 over time  :D :D
drobertson
Mojo can be like grabbing the air at times, humidity can take all the mojo even before starting,  I'm still not sure if its my clutch or slave cylinder, but between the rain, then sun and humidity as much as I hate to say it, fall can come in any time now.
I shoulda kept my mouth shut.  Another call this PM with 4-5Mbf of SYP.  He said 40-50 logs all to be sawn into 1X6's, 1X8's & 1X10's.  I plan to start it on the 16th.
sandsawmill14
magicman sounds like you better get that clutch adjusted :D :D :D
SawyerBrown
Some days I can't get it out of Reverse ...
sandhills
Really?  There's other gears?  :D
yukon cornelius
 :D I need to get my butt in gear as well. some days all I can do is grind the gears.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
chet
I'm ta da point that I may hafta try synthetic, I think my old grease is just too thick ta let da gears turn.   :-\
Ah, so that explains it  ;D.
fat olde elf
With your birthday coming up soon, I can guarantee that  your clutch will increase to slip even more.
However I will continue to admire your industrious nature. 72 is not old, just older.....You are a real role model for all ages !!!!
Cook's MP-32 saw, MF-35, Several Husky Saws, Too Many Woodworking Tools, 4 PU's, Kind Wife.
Delawhere Jack
"If you can't find em, grind em!" (old saying).
