Smashed my Stihl MS260 Pro today
Started by Lorenzo, June 20, 2015, 04:24:06 PM
Lorenzo
Had my open face notch made, as I was making my bore cut in next to the hinge the tree just collapsed down on to my saw.  turns out the side I choose to cut my notch was solid wood but the rest of the tree was hollow and rotted.  I noticed as I was making my bore cut that it went in like butter and I said O darn just as the tree crushed my saw.  Handle, left side case, and pull rope housing are broken, possibly more stuff when I tear into it.
Question is do I fix it or just buy a new saw?  It sure was a handy size and always ran good. I see them on ebay for 500 with extra chains and two bars, Any suggestions.
4x4American
Tear it apart and price out how much $ it will cost in parts and then  figure out how much $ you want to put into it.
Boy, back in my day..
sandsawmill14
that sucks   did that to my 038 some years back broke the top handle,recoil,and fuel tank. i fixed it but it was my grandads old saw so money didnt matter as much as saw. worst part of it was it had the aluminum gas tank and all i could get to replace it was a plastic one from a newer saw. if you can find used parts it shouldnt cost to much to fix :)
sablatnic
I would sit on my hands while trying to locate a cheap parts saw.
Don't know what the possibilities are in your area, but maybe a friendly dealer has one.
luvmexfood
It happens. At least your not squashed. No parts available for you on Ebay.
Give me a new saw chain and I can find you a rock in a heartbeat.
bluthum
Ow! As I get older it's easier for me to console myself about the equipment busted by noting that my body is intact.
terrifictimbersllc
Don't have a broken saw partly fixed that will make you sad whenever you look at it.  If you liked it, just go get a new one.     Save the broken one for parts it will come in handy & make things easy when stuff happens.  If you wanted a different model, make lemonade and get what you want.
Blackgreyhounds
Fix it.  As long as it's just plastic parts, handle, etc.  If the case is broke, part it out.
Those are popular saws I would look for one with a bad cylinder and make one from two. Many tree removal co's have parts saw under the bench. Frank C.
4x4American
A new 261 takes what, $600?  I'm not sure what the differences are between them.
Al_Smith
From what's been said ye olde 260 has became parts .Maybe the crankshaft,cylinder rod and piston if that much can be salvaged.
Maybe flea bay for an 026/260 with cooked cylinder or the dead pile from a friendly Stihl dealer .
clww
Forum sponsor CHAINSAWR has 7 pages of MS260 parts listed on their web page. :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
Lorenzo
I fixed it,  Or actually I sent it to a specialist in Oregon and he fixed it.
New left side engine case with new bearings and seals, starter assembly, clutch and all the chain break parts, sprocket and clutch drum, air cleaner and air cleaner cover with weather guard, top cover and wrap handle, new carburetor with dual adjustments, tuned and ready to cut.
When I got it back I put the chain and bar on and went right to work with it and It starts, runs and cuts better then it ever did before.
I really found a great guy and he really knows his way around an MS 260
Thank you John Tipton in Lake Oswego Oregon.
4x4American
Glad to hear it!  Does he do porting work too do ya know?
luvmexfood
Had a tree do something similiar to me couple weeks ago with my 590. Lucky just broke the front handle and bent one of the dogs. Had the ground not been so muddy it probably would have been worse. Rear handle was sunk plum to the hilt. Did have to clean mud from everywhere.
JohnG28
Was it all OEM parts or AM? Looks like a good job on the rebuild.  8)
Lorenzo
Quote from: JohnG28 on July 10, 2015, 10:15:10 AM
Was it all OEM parts or AM? Looks like a goof job on the rebuild.  8)
All OEM,   I wont have it any other way.  The left side case was from an 026 so as you can see by the picture, it has the good old screw in oil tank cap.
JohnG28
Nice, I didn't catch the oil cap. Fixed above post a :Dlso!
4x4American
Lorenzo
I don't impress easily about some things .
Mechanical stuff, cars, air conditioners, mowers, tractors, ect....   ect....
They wear out and need an occasional repair or maintenance .
We just expect  and take for granted that some one some where can make it right again,
I grew up a farmer and learned at a young age that you have to learn to do as much of your own repairs as you can or at least try.  I am 100% confident I could have done this myself but choose to just let someone who specializes in these just do it and get it done.
He had all the parts on hand and I got the saw back in five days, He only had it one day,  turned it right around, and sent it back. I would have had to wait longer then that for the parts to get here.
So long story short 4x4American, I have used it several times since it was fixed and it's truly better then it ever was.
I am impressed with what he did and how fast I got it back.
HolmenTree
Up north here Stihl Canada sold more 026/260's then any other model over the years. Very dependable poplar saw.
jd-ford-hd
Is anybody familiar with or have contact info for John Tipton that the OP mentioned as doing the repair?
Ada Shaker
Quote from: Lorenzo on June 20, 2015, 04:24:06 PM
Sometimes pays to smack the tree with the back of an axe and listen, but to late for that sort of advice.
If it hangs to the left, your likely to be a Husqvarna man.
If it hangs to the right, your likely to be a Stihl man.
Anything else is an uncomfortable compromise.
                             AND
Walking with one foot on either side of a barbed wire fence can become extremely uncomfortable at times.
Mikeinkaty
Always nice to see happy endings.  Thanks for sharing your experience.
Lorenzo
Quote from: jd-ford-hd on July 11, 2016, 01:04:31 PM
His number is 503-332-6803
