Every sawmill needs one of these!
Started by hackberry jake, June 13, 2015, 07:32:46 PM
hackberry jake
I have a deal with a local commercial mill to cut cedar logs on halves. He said "the keys are in the loader anytime you come down to get logs". So I went down today and loaded some logs.
Chuck White
Whew, Now that's a loader!
That thing could load your trailer with one mouth full!
etroup10
We've got one of these at work. Same model and same grapple. They sure are fun to drive! I wish I could convince my boss to let me borrow it at my mill for a day  :D
NHLA 187th class, lumber inspector. EZ Boardwalk 40 with homemade hydraulics; Gafner Hydraloader; custom built edger, Massey Ferguson 50E, American Sawmill 20" Pony Planer; Husqvarna 55 Rancher
ozarkgem
Nice size Cedar logs. Does he mill Cedar or is it just a by product he picks up?
YoungStump
We've also got two of those at our mill we keep a grapple like the one pictured on one and usually straight forks on the other, but we can switch over to buckets for cleanup and loading bark and firewood. The one we've had the longest has over 18,000 hrs and still gets the crap beat out of it daily.
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
hackberry jake
Quote from: ozarkgem on June 13, 2015, 09:37:24 PM
Just a bi-product. He buys all the timber on a certain parcel of land. His main business is grade hardwood and hardwood ties.
Bruno of NH
That looks like a good load for the yota to be pulling !
Jim/Bruno
Bill Gaiche
This must be its big brother. Nice cat loader Jake. bg
hackberry jake
Quote from: Bruno of NH on June 14, 2015, 08:01:00 AM
Jim/Bruno
I could've handled a few more.  ;D
never finished
 I'm guessing you didn't go south on the pig trail to get them. If you could have hauled many more.
ozarkgem
Quote from: hackberry jake on June 13, 2015, 11:26:32 PM
oops I spelled bi product wrong. thanks for the correction. I hate misspelling words
hackberry jake
Quote from: never finished on June 14, 2015, 09:04:29 PM
I went west on hwy 16.   ;D
Brucer
That's my dream machine. I'd even settle for one of it's smaller siblings.
As it is, I use a Cat 910 loader, which would be the same size as an IT12. The big advantages of the IT series (over a conventional articulated loader) are
1 - parallel arm linkages -- a set of forks stays level all the way up.
2 - quick change from one implement to another.
Bruce    LT40HDG28 bandsaw
JustinW_NZ
Quote from: Brucer on June 14, 2015, 11:33:02 PM
We just imported a new 10 ton Chinese built machine with a quick hitch on it for a yard machine, that is one really REALLY handy feature!!
I've been swapping between forks and bucket all day while doing some roading work when the gravel trucks turns up.
Cheers
Justin
Gear I run;
JB Griffin
Looks like you had fun Jake. ;D
How does that compare to a 950B? They got 1 at the mill I work at along with 2 Dresser's, 2 Internationals, 2 Komatzus and a Deere.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
hackberry jake
Quote from: JB Griffin on June 15, 2015, 07:02:56 PM
say_what
ScottAR
Bit smaller than a 950 I'm thinking.  A 950 is a 3.5-4.5 yard loader.  If I remember, the it28 was about a 2.5-3 yard machine.
Scott
[Magicman]
ozarkgem
Quote from: JustinW_NZ on June 15, 2015, 03:32:29 AM
Cheers
Justin
How about some pics of the Chinese machine?
Brucer
The Cat 950B has about 50% more horsepower and 50% more weight than the IT28.
I actually had an opportunity to buy one of those machines Bill Gaiche posted. It'll pick up an entire truckload of logs in one lift :o. A mid-size sawmill company with several operations in BC had gone bankrupt and everything was for sale. They would have been happy to get scrap metal prices for the machine.
It was a nice thought but that thing would fill up my log yard, I'd have to take make a 20-point turn just to get it turned around, and I don't think I could even pick up just one log with it :D
JustinW_NZ
Quote from: ozarkgem on June 15, 2015, 09:13:51 PM
Cheers
Justin
Don't wana hijak thread, but this gives you the idea..
Cheers
Justin
Gear I run;
Bibbyman
We tried out a CAT 910 years ago.  Three major drawbacks.   Too DanG tall!  We get in and out of it 50 times a day.  Climbing head hight that many times is too hard on the knees.  Too tall two - it wouldn't fit under any eve at the mill.  Three.  I couldn't live with the articulation.  I'd pick something up and turn and whatever I picked up would fly off the end.
Sawing since '94
JB Griffin
The articulation is weird alright but the loader drivers at work use it to straighten log piles up, just get the fork next to the end of the log and turn the steering wheel. ;)
Bibbyman
I can side shift about 6" with our Terexs up close or maybe a foot when boom is extended.  Here are a couple of videos I made way back when.
http://youtu.be/FVosFcvb1MQ
http://youtu.be/7UxKhvIo4J4
Sawing since '94
hackberry jake
That looks better suited for uneven terrain as well. I could see it coming in handy for a lot of things. Like setting trusses.
Dixon700
What kind of weight can that Tele handler handle?
Ms 460 mag 25" b/c muffler modded 010av  14" b/c
94 case 580sk 04.5 ram 2500
