Well, that was a bit of a shock.
Started by cutterboy, June 12, 2015, 05:02:58 PM
cutterboy
I was sawing through a cant of red oak this morning when a bolt fell down from above and landed on the cant just where the blade was passing underneath. It was a surprise! Luckily the bolt stayed on the cant and didn't fall onto the blade. After inspecting I found that one of the bolts that holds the muffler to the engine broke off.
One more thing to fix.    Happy sawing, Cutter
To underestimate old men and old machines is the folly of youth. Frank C.
Ocklawahaboy
I had a whole muffler break off of mine in the middle of a cut.  Much different setup than yours.  The old Onan.  Exhaust pipe rusted through and broke from vibrations.  We are all affected by gravity but it's never nice to see it taking a toll on the mill.
21incher
Looks like it will be a job for a easy out. :)
sumday
In my experience, whoever came up with the name "easy out" must have had quite the sense of humor.
ladylake
Is that bracket to the left of the exhaust broke, if its a muffler support that would explain the broken bolt.  Steve
dustyhat
Well, look on the bright side cutter, your into some nice looking lumber :)
Nomad
Quote from: sumday on June 12, 2015, 06:35:27 PM
:D smiley_thumbsup
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Cedarman
Percy
Ya, its right up there with root canal and colonoscopy......
gww
I had an old shovel head harley that had the exaust tied to the motor in the same fasion. My pipe fell off while going down the road.  I believe harley came up with a stud type system to counter the problim.  I just had it welded shut redrilled and tapped and didn't have any more problims.  I think it is a weak set up though.
gww
YellowHammer
The photo reminds me of when my Grandma's dentures fell out and landed on the dinner table :D
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Or when with some friends at a bar doing some beer tasting, and one older fellow came back from the men's room, claiming he'd upchucked and his new dentures went in the toilet. He thought he could just flush it and all but the dentures would remain.   Didn't work that way.
cutterboy
Quote from: YellowHammer on June 12, 2015, 11:02:29 PM
YH
:D :D :D :D
BUGGUTZ
Be careful, if you drill that be sure to get center. If you miss that steel stud in an aluminum head......... Heads arent crazy expensive if it comes to that. Hopefully theres a nub sticking up. Use some heat as well. Good luck!
Everyone has to be somewhere.
That's a stud and their usually a little harder than bolts. Buy a real good quality drill and find a piece of tube to put in the hole to center the drill. If you can find a drill with left hand flutes sometimes it will back out the broken piece after you drilled a ways. Good luck mate. Frank C.
And might I suggest that some liberal use of Blue Creeper applied to the thread area will likely be very fruitful to removal before drilling as mentioned. The left hand drill bit a very good idea along with the method of centering the bit.
cutterboy
Thanks for the suggestions everybody. I've ordered new studs and we'll see what my fix it guy and I can do. Frank, good idea about centering the drill.     Cutter
pnhd65
[/qu
ote]   That would've been Mr. Murphy. He and I are infinitely familiar. :D
The square tapered easy outs are the better design. I have had good luck with torques bits the ones you put a socket on, they seem to get an even grip and not expand the broken piece tighter. If a stud is broken off flush or buggered from vice grips you can weld a nut on it, a place to grab and the heat helps. Frank C.
nz1h
At work when the broken bolt is stuck and we don't want to stress the easy-out to the point of breaking we use canning wax.  Just drill bolt for easy-out then heat it and melt wax into the bolt.  95% of the time it comes out really easy.
alain
Good Morning nz1h, and Welcome to the Forestry Forum.  You have been mighty quiet for 4 years.   ;D
How about an intro thread and telling us about your sawing, log, lumber interest?
Welcome nz1h.
Your candle/wax trick was one I observed at a local engine repair shop. Before steam cleaning engine blocks, they would strip the old block of all studs. Quickly moved around the engine with a torch and a candle, heating the studs and then cooling them using the candle which melted the wax down around the threads. Then just turned them out easily with pliers. Only thing I've seen that is better than Blue Creeper.
Kbeitz
If you have one to hard to drill just use an old cement bit.
Cement bits dont come sharp so you need to put an edge on it.
There is not much you will find that a cement bit cant drill.
Love machine shop work
and Wood work shop work
And now a saw mill work
