lube pump
Started by jaciausa, June 09, 2015, 08:05:37 AM
jaciausa
Today's problem seems to be the lube pump. Can't find fuse, Lt 40 Super 2005 from book description.
There are a row of breakers under the long panel on the lower front of the control box.  I think 4 screws remove the panel.
jaciausa
Thanks, i found those but only one is an accessory fuse,and  it is not tripped. Instructions for a back up drip system seems to be what i need now.
jcbrotz
There is a automotive type fuse in the lubemizer panel on the right side of your control panel. At least there is on mine.
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
Nomad
     If you're talking about a lubemizer pump, mine has 2 4amp fuses in the lubemizer box.  Both of them need to be intact.
WoodMizer LT50HDD51-WR
Lucas DSM23-19
And there is one labeled F1 inside of my LubeMizer box.  The F2 is probably hiding.  ;D
jaciausa
Thanks everyone. That is where i found them! The electrical diagram was not very accurate as to where these fuses are. I blew 1 more after replacing and now i believe it is time to order a new pump, or head. i just got to remember how much i saved buying this used mill! Probably lose a week more before i get part. Sawing time lost is starting to add up fast.
drobertson
run an auxiliary gravity drip line by passing the pump until the parts come in.
Nomad
Quote from: jaciausa on June 10, 2015, 12:13:20 AM
     Yeah...  Last time I blew one of those fuses it cost me a new pump too. :'(
Lucas DSM23-19
jaciausa
Got new pump today. The only problem is the big crack in bottom of case.
