How do you cover your mill?
Started by 4x4American, June 03, 2015, 08:44:48 PM
4x4American
My mill unfortunately doesn't have a home (yet) over its head.  So, what I have been doing, is I put the console cover on, the big carriage cover, and then a big 20x40 tarp covers the whole thing.  I got caught with my pants down sawing out in the rain the other day, and I only put on the two WM covers.  I went and sprayed the rails with my blade lube mix cause that was all I had at the time (bar oil + diesel 50/50).  The rain was tenacious at times, which might have washed the mix off.  After 3 days of rain, the rail had a bunch of spots of surface rust.  When I have the big tarp on it, I never get surface rust.  But a friend of mine told me that the way his gramps keeps his tractors paint looking fresh is he never puts a tarp on it because it holds the moisture in.  I spoke with a WM service tech today and he recommended to just use my two WM covers and keep the mill painted with ATF.  After any sawing, I blow the mill off with powerful leaf blower and paint with ATF.  Another reason I like the big tarp is for security purposes, no passersby see a shiny WM they just leave it to their mind.  I don't worry about it much here at home, but I do when I'm out in unfamiliar territory.
What say you, eh?
Boy, back in my day..
Ga Mtn Man
When I have to leave it out overnight I just cover the head and console, if there is a chance of rain that is.
Since I am almost 100% portable my sawmill seldom gets to sleep under a shed.
It has to rely on these covers to keep the rain, etc. out.  I am well into my 13th year of sawing.
Dave Shepard
I have a 16'x20' tarp to cover the head. The rest of the bed and 24' extension stay out in the weather.
POSTON WIDEHEAD
Most mills are covered by:
One of our Sponsors.  ;D
AnthonyW
I tried covering most of the mill in a tarp, but it sagged and the weight of snow or rain water tore the tarp quickly. I used the remnants to cover the head but could not do it well enough. So I just cover the engine now. I hope to someday have a shed to park it under, not only for storage of the mill but also its parts and pieces and to be able to do some milling at home in the shade.
'97 Wood-Mizer LT25 All Manual with 15HP Kohler
Sixacresand
I got a 9 x 12 shelter that covers the head and controls.  It is a temporary shelter and it saves manhandling a tarp at the end of a tired day. And I have Margeson and Assoc. too.  I don't that coverage covers rain drops.
Ocklawahaboy
I was using a blue tarp and then the wife sprang for the WM fitted cover.  I bought a 10x20 tarp-carport building but haven't set it up yet.
4x4American
Quote from: Ocklawahaboy on June 03, 2015, 10:13:13 PM
The WM covers are fitted?  I haven't been able to get my carriage cover to fit right.  It kinda sorta fits, but more like a hot dog in a hallway than anything else.
WV Sawmiller
I just cover the head and controls with the WM cover I bought from WM when I bought the mill.
Peter Drouin
A&P saw Mill LLC.
License NH softwood grader.
4x4American
This is how I cover my mill every night.  The console cover and carriage cover is underneath.  I guess its overkill compared to most!
Peter Drouin
Nothing is overkill when you think of the $$$ you spend to get one. :D
A&P saw Mill LLC.
4x4American
Brucer
In the winter mine is covered by the console cover and the engine cover. The rest of the mill is covered 1) miscut boards (to keep the tarp from collapsing), 2) a tarp (to keep the snow off), and 3) snow (a lot of it).
In the summer it's covered by the console cover. It'd be covered with sawdust, too, except I brush that off every night.
Bruce    LT40HDG28 bandsaw
Kbeitz
I did it right the first time...
It stays on the mill at all times...
Love machine shop work
and Wood work shop work
And now a saw mill work
bkaimwood
I'm currently covering mine up with a pole barn roof...no sides yet, just put it up, got it under roof, and been too busy working to get back to doing the sides...up until December when it was used, I covered mine with one huge tarp, like a lot of guys do...the problem with this, is, that can actually be far worse for whatever it is covering, than not covering it at all. Like the original poster mentioned, here's the scenario...the mill is dry...It rains, and stops...now the mill is confined to a humidity chamber...the same is true after these warm, humid summer days and nights...so if you must, cover it for precipitation, but uncover it after the event, or in the morning after a humid night...I know, a real PITA, not realistic...its windy here in my little valley, so matter what I tried, the wind would either blow the tarp off, or simply tear it if it was tied down too well...as for the snow and rain, been there too, pools and pockets of snow and water in low spots too big and heavy to move, dumping all over getting everything wet, defeating the purpose in the first place....just a plain ole mess!!! My suggestion?? Start cutting and constructing the structure for mill, using the time and money you don't have, because you are too busy working your pith off to pay your bills and put food on the table...its tough to get ahead, but with patience and keeping your nose to the grind, having a plan, and a few beers, you'll get there!!! Best of luck!!
bk
Peter Drouin
A&P saw Mill LLC.
Verticaltrx
Right now I just cover mine with a silver tarp. I might switch to canvas, I think it breathes a bit more. It's important to keep everything that needs it well coated with ATF or rust preventative regardless if it's under a tarp or not. Moisture is an issue under the tarp.
Personally I believe that keeping the sun off equipment is almost as important as keeping the rain/snow off. The sun really deteriorates paint, plastics, rubber, etc.
Wood-Mizer LT15G19
It's been said that the sun also turns WM Orange into a "Salmon" color.
AnthonyW
Quote from: Magicman on June 04, 2015, 07:45:35 AM
Was that just for the old mills, or does the 'new' paint do it as well?
I can vouch for the fact a mill made in the late '90s will turn salmon pink (see pic left). I'm trying to turn the frame (which has many large rust spots) Rustoleum Lobster Red. It's looking good so far.
Ocklawahaboy
Quote from: 4x4American on June 03, 2015, 10:27:38 PM
Just the head cover.  It fits real well and is reinforced where you would anticipate wear points. Came with a bunch of bungees but I don't need them because it fits so well and is so heavy it's not going anywhere.   I don't cover the rest of the mill.  Probably should but don't.
Tom L
I keep mine in the shed now, before that I kept the WM covers on the saw head and the console
I cut some PVC that I saw another board member do here, put a slit in 1-1/4" pvc on my table saw, oiled the rails and then snapped on the pvc covers on top of the round bar rails, kept them pretty much rust free.
much better now in the shed
Chuck White
I cover mine with the Wood-Mizer cover that I got with the mill.
It covers the mast, gas&water jugs, engine, debarker and operators console.
The rail gets a coating of ATF when the mill is in operation.
The rail is some really hard stuff and I wouldn't really waste a lot of time protecting it, other than keeping the felt wiper pad loaded with ATF.
Question: For those of you who cover the Wood-Mizer rail (specifically), do you cover the bottom rail, it is exposed to the elements as well?
LittleJohn
Just cover the engine, with a canvas-type cover.
Controls are the old manual style, so never cover them.
