WM debarker alarm
Started by delvis, June 01, 2015, 09:14:17 AM
delvis
Before we bought our mill I thought the first thing I would do would be to take the alarm off the debarker because it is so loud.  Once we started using it, it was easy to see how nice it is to have a reminder that the debarker is on.
Our alarm just quit working the other day.  Now it makes a low humming shrieking sound.  Has anyone used a replacement other than what WM has?  Where did you get it, and how well does it work?
If I never saw another board I will at least die happy having spent the last few years working with my dad!
Chuck White
I tried a vehicle type backup alarm, and it didn't work.
Go with the one WM sells for your replacement.
Something in the wiring is different.
I did cut the red wire on mine and put a small "out of sight" toggle switch on it.
When I have a customer (and/or offbearer) with little or no experience around a mill, I turn the alarm on and after a little experience is gained, I'll turn it off, because it is quite loud over on the other side of the mill.  I usually don't even hear the alarm over on the operator side of the mill.
POSTON WIDEHEAD
Mine went out and started the low humming sound. Yep....I cut the wires and have not looked back.
Its easy for me to see if the debarked is on or off.....I just look. ;D
Are you saying that the little horn thingy is supposed to make a noise??   ???
WV Sawmiller
I guess the next time I crank up the mill I will have to turn on my debarker and listen to/for it on the other side of the head. I can't say I have every heard it but don't have any plans to disable it at this time.
Peter Drouin
I only had the mill 5 min and I fix it. ;D
A&P saw Mill LLC.
License NH softwood grader.
4x4American
Quote from: Chuck White on June 01, 2015, 06:06:39 PM
I like the toggle switch idea.  I've gotten complaints from the alarm before, as it was scaring animals, but I didn't want to disable it completely.  Seems like a toggle switch is in order for me!  Thanks!
Boy, back in my day..
Tom L
 I wrapped mine in duct tape, now it only makes a low twerp instead of a loud beep.
I would say order the right one from WM
drobertson
Mine still works, and seems loud enough, I have thought about putting a light in the circuit instead, but never have. I sure would hate for someone to accidently get debarked by it.
jkeith
Quote from: drobertson on June 03, 2015, 09:16:42 AM
:D :D :D I hate when that happens. I suppose one could replace the beeping with a recording of an hysterical women screaming "look out! look out!"
plowboyswr
Quote from: jkeith on June 03, 2015, 10:17:32 AM
At the factory where I work they installed an alarm on a machine so that people working around it would hear that it was being started. They got they most annoying woman in the plant to record her voice. When it was played over the speaker at the machine no one could tell what she said, of course when the boss heard it once he thought a "dirty" phrase was said and promptly had it changed to a beep!  :D
Just an ole farm boy takin one day at a time.
Steve
mesquite buckeye
I debarked a hardhat once before I figured out what that beeping is for. I'm glad it is there. ;D
Sixacresand
I use ear plugs or muffs, not for the debarker alarm, but for the screeching sound when the engine engages.  very irritating.
I use ear plus to try and salvage what hearing I have left.
Nomad
Quote from: Magicman on June 03, 2015, 01:53:05 PM
     Me too.  But I'm strictly mobile, and I think that alarm is pretty important in my situation.  I've had a couple of complaints about it (from neighbors to the customer) but I think the safety factor outweighs their objections.  I wasn't shy about pointing that out, either. ;D
WoodMizer LT50HDD51-WR
Lucas DSM23-19
4x4American
I disconnected mine today, because I've received various complaints due to it.  If I have a real green tailer I will plug it back in.
YellowHammer
Quote from: Tom L on June 03, 2015, 08:41:34 AM
I used a few wraps of electrical tape until I got the sound damped to where it was loud enough to hear but quiet enough to not have my teeth rattle.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Brucer
I didn't have a debarker on my first mill (which was set up behind my customer's timber framing shop). When I got the new mill with a debarker, I left the alarm connected for a couple of days. Then I watched one of the timber framers nearly step out in back of the shop's forklift as it was backing up. The backup alarm made exactly the same sound as the debarker alarm.
Folks had got so used to hearing the debarker alarm right behind the shop that they just started to ignore it. Everyone was pretty scared by that incident and I decided it was safer to disconnect the alarm. I spliced in a couple of plug-in connectors so I can reconnect the alarm whenever there's visitors around.
I devised a control circuit with a relay and a couple of push-buttons that will let me turn the alarm off (or on) with the push of a button. It will reset itself to the "on" condition every time the power is interrupted. That way it will always start off beeping and I will have to deliberately turn it off each time. Haven't built it yet because I can't find affordable (i.e. cheap) weatherproof pushbuttons.
Bruce    LT40HDG28 bandsaw
I have no idea about the WM alarm,but the forklift alarm you should be able to get one.I use to work at a place that the equipment made ALOT of noise. The forklift mechanic said he could put another alarm on the lift so we could hear it better. He said there are diffeant ones to try.
