Finishing lumber
Started by JHEPP08, May 20, 2015, 10:45:09 PM
JHEPP08
I have a small sawmill operation . Was wondering what most you guys do.. Do you run everything through a planer an edge a side with jointer? Or do you do that as a extra an what do you guys charge? Also with wet lumber do you cut it about 1 1/8 to get 4/4 ?
Woodmizer LT15
I plane the lumber.  It is cut 1 1/8" and I plane it to 1" or 15/16".  I do not striaght-line it on the jointer, but will do that for small quantities for a fee.  I usually add $.50/bf for doing extra processing/planing/jointing, etc.
Ribsy
WDH, do you plane it straight off the mill or do you dry it first?
Engaged in tree work, tree removal, milling and and processing said product into high quality and well seasoned lumber slabs and firewood.
JHEPP08
Woodmizer LT15
