John deere 350
Started by 4430jd, May 15, 2015, 09:18:35 PM
4430jd
anyone in the forum working with a john deere crawler loader. I recently found a 350 model and have a  few guestions. Thanks.
WH_Conley
I had one years ago. 350, no letter after the number. If I remember correctly mine was a 1965 model.
Bill
sharp edge
Let the ? roll, before you disappear. :o
SE
The stroke of a pen is mighter than the stroke of a sword, but we like pictures.
91' escort powered A-14 belsaw, JD 350-c cat with jamer and dray, 12" powermatic planer
shinnlinger
@mbunten mbunten@  I forget how to tag, but mbunten has a 350 dozer he has been thru and I discussed a loader/hoe unit with him I was looking at.  He seems to know a fair bit about them so ask away.
Shinnlinger
Mbunten
4430jd,
I have a JD 350 crawler dozer, which I'm fairly familiar with, but I dont know a ton about the shovel dozers.  I know from talking to a local retired JD mechanic, some of the problems with a hoe can be premature sprocket wear depending on how much traveling you're doing with the hoe on.  Another problem area with these smaller crawlers was the bolts that hold the reverser to the transmission housing, and the sideframes cracking from the stress of something like a log arch or a hoe hanging off the back.  Again, these are great little machines in my opinion, but they have a limit. If they arent pushed past that limit, you'l get many years of service from it. Im sure there a lots of other guys on here that could comment or have way more knowledge than I do....
Matt
Carpenter, furniture and cabinet making. Maple sugaring, Christmas trees, seasonal firefighter and prescribed fire crew member, USDA Forest Service, NH-WMF
1970 JD350 with forestry package, JD 2038R with grapple and Igland 3501 winch. Stihl and Husky saws
grweldon
I own a 350B crawler/loader.  I know a bit about it.  Enough to know that the 350 and the 350B are slightly different, not necessarily in good ways either!  I may be able to help.  Mine is down at the moment.  Will need the engine removed for diagnostics but it does run.  It's down now because the rear main seal is slinging so much oil into the starter that it kills the starter.  I'm sure I'll find more wrong than just the seal when I get the engine out...
My three favorite documents: The Holy Bible, The Declaration of Independence and The Constitution of the United States.
coxy
I can help to    I have 3 running 350-b-c  and 3 for parts have been looking for a d but cant find one around here   that way I have them all ;D some of the straight 350s had power steering and some did not they work off a pump on the front of the motor   the Bs work off the  reverser much nicer   the bucket loader track frames would bend also from picking way way more then there suppose to  :D  great little dozers we have had the old 350 over 35years and still runs and does its job when needed all have winches  but I like the 350c the most 22years and no steering clutches have rebuilt the blade a few times over the years and put 2nd gear in it 3 times I have books for all so if any one needs any info just let me know will be glad to help
snowstorm
a toqure converter in a 350 jd........no
coxy
gradetracy
I got one from tractortool store recently, and it is a great option, I guess. Works fine for me, nothing is wrong
grweldon
Quote from: gradetracy on May 28, 2015, 10:34:19 AM
What exactly was it that you got?
sharp edge
I thought 4430jd would disappear after reading the name of his town.
SE
