Lumber trailer
Started by JHEPP08, May 13, 2015, 01:58:57 PM
JHEPP08
Ok I would like to see what you all use for hauling boards away from the mill so they can air dry etc. I have a couple old wagon running gears . Just want something I can load an unload with forks etc easily
Thanks in advance
Woodmizer LT15
fishfighter
I stack and sticker right off the mill. I use my tractor with forks to lift and move to a new spot and cover.
Wagon running gears work very well.  But still need to sticker the lumber to get it to air dry.
JHEPP08
Yea sorry should of said that . I plan on stickering I just meant what do you use? My running gear has nothing so I'll have to fab up something I can fork easy etc ..
Also how or what do you put dry lumber on to store ? I have a controlled environment for it to be in
Woodmizer LT15
sealark37
To answer your question, the deck should be long enough to take the longest lumber you plan on producing.  It should be as flat as possible, and should be wider than the wheels.  I assume that you have four-wheel farm undercarriage.  If not, the tongue jack should be rated to hold the loaded trailer.  You need several strong points to secure tie-downs for road travel, even short distances.  Regards, Clark
78NHTFY
...to save time handling boards, I put them right on the forks of my tractor loader from the sawmill, and after sawing 2-3 logs bring the boards to where they are to be stacked--like fishfighter said.  The more I handle lumber, the less I get done. :(  All the best, Rob.
If you have time, you win....
fishfighter
At the end of my mill, I have two 8"x8"'x4' that are spread apart about 6'. I stack/sticker on top of them till about 3 1/2' high. I'm able to stack two stacks together, one on top of the other.
On one side of the mill, I have some sawhorses set up for of cut size lumber that I stack up till the end of the day. That is when I cut more stickers.
Areas I store them, I have 6"x6"x 5' set up at about 20" apart. Use tin sheets to cover.
drobertson
Sticker stack and try not to double handle too much, unless you like it ;D
tmarch
Quote from: 78NHTFY on May 13, 2015, 04:32:54 PM
The only other thing I do is remove the sawdust before stickering.  I'm a 1 man show most of the time so any time saver is a +.
Retired to the ranch, saw, and sell solar pumps.
fishfighter
[quote
[/quote]
Good Lord I have some sawdust moving ahead of me. That is something I haven't done in some time. :D
JHEPP08
Great info. Any pictures of your set up? I'm small more quality then quantity but saving my back an time I'm looking for!
Woodmizer LT15
ladylake
 I always though old wagon gear with no bed worked good, the lumber sits on the bunks with plenty of room under to get forks in, not very good for getting around with.  Steve
Chuck White
Quote from: ladylake on May 14, 2015, 05:33:07 AM
That's what we use around here.
We just add a couple of short 2x4's on edge just beyond both ends of the reach, to help with sagging lumber.
We also use the running gear to haul logs!
JHEPP08
Anyone have any pics of their set up?
Woodmizer LT15
