whatzit?
Started by hackberry jake, May 11, 2015, 09:45:04 PM
hackberry jake
This came in a box from a shut down industrial maintenance shop. Appears to be cast iron with two machined surfaces and three adjustable feet/thumb knob things. Whatzit?
gww
A very heavy duty magazine rack.
gww
POSTON WIDEHEAD
It was used for shoeing Goats.
Don_Papenburg
Shucks we use a double barrel 12 ga. to shoo goats.
I reckon you could use that  for checking shafts and pulleys for balance or kinks?
Adjust the feet so it's completely level, then roll the shaft along the knife edges. If it wasn't in balance, you would soon see.
OR else it's the worlds biggest napkin holder.
POSTON WIDEHEAD
Quote from: Ianab on May 11, 2015, 10:27:56 PM
:D :D :D I think we have a winner!
justallan1
Near as I can guess I'd say pack-rat poison and you been bit, but I would have hauled it home too.
I do like Ianabs' thinking on it though. If you wanted to balance a shaft, pulley, flywheel, Etc. that would work perfect without the time wasted mounting it up in a set of bearings, plus it would be free of any resistance.
CRAP! I need one. ;D
Quote from: Don_Papenburg on May 11, 2015, 10:25:57 PM
How far will it shoo a goat? Far far awayyyyyy ??
The Whatzit looks like ways for a sliding part, like a carriage (only sliding a short distance however :) )
Might make a decent base for a planer knife blade sharpener.
Chuck White
Looks like it could be some sort of grinding jig!
Brucer
Ian's right. It's used to check the static balance on a shaft (usually with something mounted on it, such as a gear, pulley, fan impeller).
Bruce    LT40HDG28 bandsaw
PC-Urban-Sawyer
Quote from: beenthere on May 11, 2015, 11:26:01 PM
Quick research says 40 to 60 yards for bird or buckshot...
:D :D :D :D :D ;D ;D ;D ;D :snowball: :snowball: :snowball:
Herb
Don_Papenburg
The closer you are to the goat the farther you can shoo him
pineywoods
Balance table for planer heads, especially the old square heads...
martyinmi
Ways extension for an older lathe maybe? The rail design looks similar to my old (40's) South Bend flat belt lathe.
No God, No Peace
Know God, Know Peace!
21incher
I would have to guess the removable ways section from a gap bed lathe. :)
Dave Shepard
Definitely not a lathe extension. I buy the static balance suggestion. You will nee a machinery's level to set it up.
