My Mill Is Slowing Down Half Way Through
Started by Tree Dan, May 01, 2015, 07:07:48 PM
Tree Dan
What would cause my LT-40 to slow way down on every cut right in the middle, or center line of the mill?
It's the travel speed that slows...a few cuts It stopped.
I took the cover off the drive belt and It was not clogged, and did not appear to be slipping.
Wood Mizer LT40HD, Kubota KX71, New Holland LS150, Case TR270
6400 John Deere/with loader,General 20" planer, Stihl 880, Stihl 361, Dolmar 460, Husqvarna 50  and a few shovels,
60" and 30" Log Rite cant hooks, 2 home built Tree Spades, Homemade log splitter
Ocklawahaboy
Mine has done that based on lack of chain maintenance.  It happening is the same place every time reinforces that suspicion.
Tree Dan
Its oiled up.
One more thing...last job I was on the chain...travel chain was hitting the main mill beam...Theres marks on it.
Let me get a picture.
Dave Shepard
Tree Dan
Tree Dan
This happened last week...But it was not slowing down on travel.
Tree Dan
I don't know what happened...maybe a stick got in there.
Dave Shepard
If that happened suddenly, then you may have a bad bearing on the feed shaft. Speed pot is the speed dial on the console.
Tree Dan
Quote from: Dave Shepard on May 01, 2015, 08:16:35 PM
Thanks Dave..I will have a look at that In the am
I have the week end to work on it...but Im back on the job on Mon.
This machine is kinda new...I just need to look it over tomorrow
Nomad
     Are your rail and felt strip clean and lubed, so you're not getting binding there?
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Tree Dan
Quote from: nomad on May 01, 2015, 08:39:02 PM
No binding in there...its lubed with Fluid Film.
The scratches on the main beam are not related to this...that was last week.
From the last job to the job today, It almost stops in the middle...then powers through at the end of the the 4 feet of log
chief613
just a troubleshooting suggestion. turn ur speed down and manually push through. Might tell you if its friction or electrical problem
lt40hd
Tree Dan
Quote from: chief613 on May 01, 2015, 08:54:40 PM
I will try that ..Thanks
With no log on the mill the head travels back and forth free
Thanks for the help guys
4x4American
speed pot is the speed potentiometer (not sure spelling).  Do you use fluid film on the chain?  How do you like it, does sawdust stick to it much?
Boy, back in my day..
Ocklawahaboy
If the head travels through with no log on the mill, then it would lead me to think you have a problem caused somehow by the sawdust.  If you were having a problem with power, I would think that it would get slower as you went farther down the log, not speed back up.  Your mill is a lot newer than mine so I don't know exactly what components it has but I would be looking at every little thing that sawdust could be getting in.  On mine, I would look the plastic rail wipers that keep the sawdust out of the way of the cam follower bearings.
Tree Dan
Quote from: 4x4American on May 01, 2015, 09:08:56 PM
Hey 4 x ...I like the Fluid Film way better that Trans Oil
Keep a can by the mill all day long ;D :D
4x4American
how does the bottom rail look?  Also, there is a ground on the bottom rail, I wonder if the spot where it slows down has a bad ground area on the rail.  Not sure about how many hours you need to adjust the tension on the ground.
isawlogs
 Have you found what is the issue yet ???
I would take the cover off the drive belt and cut a log with it off, the belt may look tight but may not be tight enough and slip once into the log and warmed up. I have had this on my mill and it had me scratchin' my nuggin.
   Marcel
Tree Dan
Quote from: 4x4American on May 01, 2015, 09:14:59 PM
Not sure...I may need to get the big  book out and see what I should have been doing :o
Could this be a leval problem?...Its strange it powered through on my last job...this job it slows right down in the middle....
isawlogs
 Its not a level issue, you ncan run them mills quite off level.
How many hours on this mill?
   Marcel
Tree Dan
Quote from: isawlogs on May 01, 2015, 09:26:10 PM
I did that....I ran the mill with the cover off...just so I could watch it...looked Ok
kenlt30
On my  mill, the set screw that holds the drive sprocket was loose. The chain made those same marks as yours and could be rubbing enough to slow the head.
Tree Dan
Quote from: isawlogs on May 01, 2015, 09:29:19 PM
80 hrs
4x4American
Just set it so that you have a 1/2" pitch per foot towards the end of the mill and run it!
(JK)
Tree Dan
Quote from: 4x4American on May 01, 2015, 09:32:12 PM
(JK)
Not sure what your saying
