WM tips and tricks
Started by 4x4American, April 28, 2015, 10:01:31 PM
4x4American
Here is something that I have found not everyone knows about their Accuset II.
http://youtu.be/PKZlshCpnDM
Share any other tips and tricks with the WM's that you might have!  Even if it might seem obvious to you, others might not knows it!
Boy, back in my day..
POSTON WIDEHEAD
You drinking Purple Drank?  :o
4x4American
drobertson
now that's a tip I have not seen! :D
all said, nothing else to be said ;D
Peter Drouin
What was that??????????????????????? :D
A&P saw Mill LLC.
License NH softwood grader.
terrifictimbersllc
Neat! don't try that during a cut.
Jemclimber
What language or dialect was that? I need an interpreter.   :o          :D
lt15
Ga Mtn Man
For those of us without Accuset,  please explain what you are showing us  ???.
Dave Shepard
All I heard was 10 13/16 and something is fishy right here. :D At first, I was waiting for someone to make a bid. :D
I am glad that the snow finally melted up there, 'cause cabin fever is a bad thing.
Ga Mtn Man
Sadly for 4x4, I fear the spring thaw has come just a little too late.  :'(
Percy
Quote from: Ga Mtn Man on April 29, 2015, 07:50:50 AM
When you are in the manual mode, a push of the down button will bring you to the nearest inch....
4x4American
I thought it was pretty self explanatory!
4x4American
Quote from: Jemclimber on April 29, 2015, 07:06:32 AM
Thats american in the key of C flat major
Ga Mtn Man
Quote from: 4x4American on April 29, 2015, 05:18:35 PM
The video playback on my computer is pretty sketchy.  It probably would have been self explanatory if the video wasn't spittin' and sputterin'.
I'll add a tip:
For those of you with AutoClutch, if you quickly toggle the switch ON then OFF (with the engine turned OFF) you can release the blade brake but not engage the drive belt.  This allows you to freely turn the band for whatever reason you might want to do that (inspect the blade, clean the blade, check the tracking etc.).  Don't forget to cycle the AutoClutch before starting the engine.
4x4American
Thanks for sharing, Paul! Didn't know that.
terrifictimbersllc
I nominate him to auction off a roasted goat, in the event someone donates one to FF.
drobertson
something fishy?  not the way I use it for sure, pattern mode and auto up is the main stay for me,
POSTON WIDEHEAD
Quote from: terrifictimbersllc on April 29, 2015, 06:37:03 PM
:o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o :o
4x4American
Quote from: drobertson on April 29, 2015, 06:50:13 PM
Lol I don't saw like that!  This is just to demonstrate a useful feature.  One of those things that comes in handy every so often.  Like a chainsaw, normally I use it to saw wood, but I can also use it to open the lock on the passengers side door when I don't feel like reaching across, or can use it to open a beer bottle or cut a hole in the ice.  Instead of diddling the drum switch to get to an even number you can just press the down button after you get it close.
thechknhwk
thechknhwk
4x4American
Nailed it!  Boomhauer for sure!  8)
