new homemade sawmill
Started by 1967Stroker, April 26, 2015, 08:30:39 PM
1967Stroker
i started on one a few weeks ago. hope to post pictures, when i figure it out
Hilltop366
Welcome, hope you figure it out!
1967Stroker
well its got 16" wheels and will run a 153" long blade
1967Stroker,welcome to the forum. Lots of building going on lately. What's the plan for the lumber?
1967Stroker
1967Stroker
build a small cabin to live in and get away from rent
fishpharmer
Welcome to FF 1967Stroker!! Nice setup you have going there.  What part of MS?  I'm near Meridian.
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
1967Stroker
first built one using to back half of a snapper lawn mover. lol. it would work but to much adjusting to get it to track. so scraped that idea and started over.
1967Stroker
Quote from: fishpharmer on April 26, 2015, 08:56:22 PM
im in philly.
Welcome to the Forestry Forum, 1967Stroker, and congrats on the pictures.  Looks like you are NE of Carthage.   ;D
Will the pillow blocks be below the head frame to give you a deeper throat opening?  Just curious.
1967Stroker
it will be flipped over. just got it laying upside down figuring things out
fishpharmer
  Looks more NW of Carthage.
1967Stroker
2000 pound winch and 4 pulleys will raise and lower head.
1967Stroker
32" between post so maybe i'll get to cut around a 28" log
 smiley_thumbsup on the "flipped over".
Sorry, NE of Canton and due West of Carthage.  I cheated and looked at his profile pin map.   ;D
fishpharmer
It really looks stout!  What horsepower motor will you use?
1967Stroker
brand new 8hp right now. but might need to change it later. but i got my speed of feet per min, figured out. full engine power should be around 4700 FPM
fishpharmer
The blade speed will be just right.  8hp is a good start, you find that you will always want more. ;) :)
1967Stroker
worked on my guides this evening.
fishpharmer
The guide supports look great.  Woodmizer and probably most other mill manufacturers recommend a 1/4 inch of downward force below the plane of bandwheel travel.  That's on each side.  It appears that you have enough adjustment for that.
fishpharmer
Here's a good video showing blade guide roller alignment on a woodmizer.  About 3:00 minutes in is most relevant.  The 1/16" offset of in/out adjustable roller side of blade is for woodmizer cantilever head design only.
http://youtu.be/QDcmW2IgFXg
1967Stroker
going to build the slide guide tomorrow.
1967Stroker
thats the slider guide i fixed today. almost ready to tear it down and finish some welds and paint it, then get it back together.
fishpharmer
1967Stroker
thanks. i can't weld. lol. but i do ok.
