WM Transducer Question
Started by 4x4American, April 26, 2015, 03:13:11 PM
4x4American
Is this right?
If you can't tell what I'm talking about, there are two of these magnets here.  They are very loose, they rattle around and such.  I am wondering if this is why I have a transducer error message on my screen.
Boy, back in my day..
woodmills1
sparks will let you know soon, if not call woodmizer indy and ask for him.
Dave Shepard
I just got your voicemail. I've been in a dead zone all day. I'll be home before dark and I'll check mine.
4x4American
Dave Shepard
I have a single black doohinckus rigidly mounted. I don't think it's a magnet, at least it didn't try to attract a steel bolt I offered it. :D But it does somehow influence the transducer rod. If your black doohinckus is wobbly, then I don't think it can get a proper reading. May also explain intermittent problems. What does it show in the parts book? Are there two doohinckus's or one?
Dave Shepard
Go tighten your doohinckus and get back to us. The suspense is killing me. :D
4x4American
The owner's manual says there should be one doohinckus there.  It says that you are supposed to put it together loose to tighten it up later, so I can see what happened, the mill was put together on a monday or a friday and the tech put on two magnets by accident and also forgot to tighten them up.  Just a little goof up.  What I wonder, is if there is a certain procedure to remove it and if I have to recalibrate the accuset II afterwards.
I am not sweating it.  The quality of the design and build of this mill is incredible.
Dave Shepard
It looks like a piece of HDPE, or UHMW plastic. If there's only supposed to be one, I'd cut it in half to get it out.
4x4American
In the book it is hard to tell.  Page 3-1 of the equipment manual has an exploded view of it.  I can't tell which is which.  Number 15 (Magnet, Balluff Transducer, part number 038658) or number 26 (Bushing, Transducer Vibration Dampener, part number 071357)
4x4American
JB Griffin
Congrats on the new mill, I somehow missed that.
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
4x4American
Thanks JB.  Refer to the A Day Sawing Wood thread.
JB Griffin
10-4 Little Buddy will do. ;D
4x4American
4x4American
Quote from: JB Griffin on April 26, 2015, 10:26:04 PM
Little! lol I'm 6'2" weigh 230 pounds of twisted steel and...well you know the rest
JB Griffin
Very nice mill, I didn't know there was a 36hp option for a super.
4x4American
Quote from: JB Griffin on April 26, 2015, 10:36:08 PM
It's a 35.9  WM calls it a 35 horse so someone doesn't sue them for calling it a 36!
MartyParsons
Hello,
Yes one is the magnet and the other one is a vibration damper.
If you dont have the damper don"t sweat it. It is a new thing.
We had a customer come last week. He also had a error. The bolts that hold the black bracket that holds the scale was loose and the magnet bracket was hooked to it. I tightened  the 5/16" bolts and the error went away.
Hope this helps.
Marty
Percy
Quote from: Dave Shepard on April 26, 2015, 07:19:52 PM
Huh.....I drove all the way down to Doohinckus's-R-Us and they never heard of magnetized ones.... :D
customsawyer
I have had that message show up and it was the transducer cable loose. It could be in the back of the Accuset box or on the bottom of the transducer. Make sure those connections are tight before you fight anything else.
www.thecustomsawyer.com
4x4American
I have went through every and any cable that is connected in line with the transducer.  The connector on the bottom of the transducer had some salt from the ride home.  I cleaned it out with electronic cleaner and blowed it dry with compressed air.  Made sure has good connection.
Peter Drouin
So did you tighten the 5/16 bolts that Marty was talking about?
A&P saw Mill LLC.
License NH softwood grader.
4x4American
I got some different answers and wasn't sure where to go with it, and when I got back from day job today it was raining, didn't feel like taking off the tarps/cover I have on mill to tighten up some bolts and test it.  Hopefully tomorrow its nicer out.  I should be switching to part time soon to get going with the mill just waiting for enough work.  I know it will come, last year was busy!
Peter Drouin
You did say they were loose, I think?
So the rain will be here Wednesday, :D :D At least it's not SNOW :snowball: :D :D
A&P saw Mill LLC.
POSTON WIDEHEAD
I thought Marty was still at the Garth Brooks concert.  smiley_guitarist smiley_trap_drummer smiley_singsongnote01
