Kiln Fans
Started by logboy, April 26, 2015, 02:52:35 PM
logboy
I need to order additional fans for Ebac and Nyle kilns that I will be building in the future. Is there a source other than Nyle or Ebac for the 16" fans?
I like Lucas Mills and big wood.  www.logboy.com
scsmith42
JR, when I bought my L200 back in '03 I noticed that the fan assemblies were sourced from Graingers.
At one time I had the part number, but when I checked into buying them direct I discovered that Nyle buys in such a high volume that they are reselling the fans for basically the same amount that you would pay Graingers.
Tom's 3638D Baker band mill
GeneWengert-WoodDoc
I have had several clients that have had the same experience as SCSmith42.
At Graingers, you can get some fans that are low cost with low hp, no bearings, etc.  Fans are one item that "you get what you pay for."  Do not scrimp.
