Garrett, What is this part/tool/fixture?
Started by tantoy, April 25, 2015, 10:24:19 PM
tantoy
I know is has something to do with the ends on cable right?
Its mounted on the rear frame of the skidder.
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
mad murdock
I do not know what that is, but that skidder is looking real nice!!
lopet
Never seen something like that. Is that bottom part sliding back and for ? And located right below the winch ? I am curious too.
4x4American
Boy, back in my day..
tantoy
The middle or center part slides back and forth. You can make out circular imprints in the steel from someone hammering something like a cable end , so someone in the past used it quite a bit. I figure it must be for something like this
http://www.labonville.com/916--58-cable-size-Ferrule-Wedge--Pink--LB5_p_867.html?
I have never touched a Garret,but wonder did someone add that on themsleves?
teakwood
Quote from: tantoy on April 26, 2015, 11:12:29 PM
Thats it! quite a good idea to tighten the ferrules. and the whole thing is welded into the frame
MT logger
Its for crimping the ferrel end when building your own chokers I've seen them on all the older Garretts.
John Woodworth
That is for holding the tail when tying a knot in your mainline, there is a wedge on the slotted side that once you put the tail in fixture drive down the wedge to tighten the jaws then drum in to tighten knot and trim off the tail, works wonderful.
Two Garret 21 skidders, Garret 10 skidder, 580 Case Backhoe, Mobile Dimension sawmill, 066, 046 mag, 044, 036mag, 034, 056 mag, 075, 026, lewis winch
lopet
John Woodworth
I wouldn't know how to post a drawing but with a E mail I can send you a drawing of the wedge, these were factory installed and a lot of people welded a cable cutter alongside, let me know if you want the specs on the wedge.
