chainsaw oiler
Started by bullsram, April 20, 2015, 11:09:11 PM
bullsram
I bought a new saw the other day and the adjustable oiler was set at half way open. I was just wondering if you guys turn them all the way up or just run them how there set. I turned it all the way up. Bar is 25 in on the saw. Thanks Bullsram
sawguy21
What saw do you have and what are you doing with it? If you are milling the extra oil is almost mandatory. If bucking softwoods it is probably set correctly.
bullsram
It's a Stihl MS660.  I'm mainly using it for felling some large trees on my farm.
CCC4
Turn it all the way up, wont hurt a thing
DaveP
     I put a high volume on my 660.  A little extra oil won't hurt.
davep
celliott
Quote from: CCC4 on April 20, 2015, 11:54:09 PM
Unless it runs out of oil before fuel  ;)
Not a problem on a 660 even with only a 25" bar?
Chris Elliott
Clark 666C cable skidder
265rx clearing saw
Hitchcock Woods
Oil is cheap, chains and bars are not!  In SC heat we run every saw on the the highest oil setting.  More oil/ less friction.  I do, however, use different viscosity oils for different weather conditions (Winter vs Summer)
Chain Saws         Vehicles            LogSplitter
MS 192TC          6100D x2     TimberWolf TW3
MS 391               L2800
MS 441              HPX Gator
346XP           Honda4x4 Rancher
372XP              4x4 Frontier
HT 101 x2
MS 311
