4 deg. blades and knotty logs
Started by DMcCoy, April 13, 2015, 08:51:04 AM
DMcCoy
I have been using 7 deg blades in Doug fir.  The knots are creating waves, especially the spike knots.
I try new blades, going slower, more tension.  The knots are @ 2-3" in 16"+ logs.
Not so bad in full width cuts but cutting the easy way through cants is another deal altogether.
Suggestions?
I have never sawn Doug Fir, but I have found that when sawing mature trees, knots are bad, regardless of the species.  During the past couple of weeks, I have had to resort to 4° blades while sawing 26"+ White Oak and Pine logs.
DMcCoy
I think Doug Fir is a little tougher than Pine but the knot issues would be similar.
Anything you do special?
Have you used 4 deg blades in knotty logs?
Quote from: DMcCoy on April 13, 2015, 09:11:44 AMAnything you do special?
Yes, I use plenty of "Cascade" lube to keep the blade free of pitch buildup, and yes, 4° blades do very well with knotty Pine.
Ga Mtn Man
Did you notice any difference in your cutting speed with the 4° blades?
Remle
I only use 10 degree blades so no comments on blades but, have you tried cutting the log from the small end ? I've had better luck that way, the blade cuts the grain at a steeper angle and dose not seem to follow the long sloping grain while cutting from the larger end. For but logs I cut from the large end/ butt, for the same reason.
Peter Drouin
Instead of going slow go faster and see what happens. A lot of times the tooth will eat the knot and cut flat, go slow and it will ride up over, A sharp blade will cut flat. And if you go real slow you won't live long enough to get the log cut.  :D :D Have a sharp blade and try it.
A&P saw Mill LLC.
License NH softwood grader.
barbender
I just sharpened some blades on my Cook's sharpener to 4°, my initial impression on white oak is good, but I haven't sawn enough to know for sure how I like it. From what I've read on here, I am hoping to gain a couple of things- 1.Increased stability in the cut and 2.Hopefully holding an edge longer the dry white oak dulls blades fast.
My personal experience is that the 4° blades dull faster.  Since they are closer to 90°, they are doing more "scraping" where the 10° blades do more "cutting".  Just my experience, and reason for those thoughts.
caveman
Yesterday Jmoore and I quarter sawed some big live oak slabs using a 4° blade. Until this blade/job, we have only used 10° blades.  The 4° blade sawed flat and left a nice, smooth finish.  The blade did cut slower at the end of the day.  Initially, I am pleased with the 4° blades in what is usually a challenging wood to saw.  Also, we decided to coil and tie the 10° bands with a red zip tie (three letters in ten/red and tie the 4°'s with another color).
This log was 48" on the big end and we were using smallish saws (545 and 359 Husqvarnas to rip).
Caveman
Caveman
Nomad
     Caveman, calling Live Oak "challenging" is like calling the Grand Canyon a hole in the ground.  I'm glad to hear 4 degree blades worked on it; I'm ready to get some of 'em too.  I absolutely hate sawing live oak!!!
WoodMizer LT50HDD51-WR
Lucas DSM23-19
Dave Shepard
I've heard live oak is some of the toughest sawing around. The only live oak I know of in MA is in the ocean. Jim_Rogers sawed some up that had been submerged for a long time. Tough going.
customsawyer
Live oak is like sawing pecan. Some logs are easy and some are knot. ;D
@DMcCoy are the 7° blades you are using, are they the turbos or the regular?
www.thecustomsawyer.com
On no.  The mention of sawing pecan gives me nightmares.  Live oak is probably worser.
Then would Hickory be more worser??   ???
POSTON WIDEHEAD
Quote from: Magicman on April 13, 2015, 09:16:14 PM
.......... more worser??   ???
You're one of dem that talks funny ain't you?  ;D
BCsaw
DMcCoy, I cut a lot of Doug Fir with 10° blades and no issues. I sawed a 35" diameter log yesterday and it had some big knots, again no issues.
I have had some issues with waves on really wide cuts though. One issue was a dulling blade. Easy fix. There was also a time or two that the blade seemed sharp enough but still tended to surf. Thanks to the forum and advice from guys like Peter, I experimented pushing faster. My instinct was to slow down in the wide cuts, but I tried going faster and kept the engine "well into the governor". Success. Thanks Peter D! :D ;D
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
POSTON WIDEHEAD
Wider cuts need lower head speed due to the blade having more flex when the blade guides are at their widest.
This pertains to all blades.
BCsaw
Understand that I only have 13hp. I do not have the speed capabilities of a lot of people on here. My sawing quicker does not amount to a whole lot, but I believe it was forced to cut through as opposed to finding another path.
My 2 cents.
POSTON WIDEHEAD
4x4American
I like the 4 degree blades in frozen pine, what do you guys like for summer time pine sawing?
Boy, back in my day..
POSTON WIDEHEAD
Quote from: 4x4American on April 13, 2015, 10:08:09 PM
I use the 4 degree and LOTS OF LUBE in the resin days of summer.  ;D
Peter Drouin
Get some 7°/ 55 and give her some. :D
A&P saw Mill LLC.
Peter Drouin
Quote from: BCsaw on April 13, 2015, 09:50:24 PM
My 2 cents.
A lot of guys think If I go slow it will cut flat, And all your doing is dulling the blade. ;D
A&P saw Mill LLC.
Just because its softwood doesn't mean it will cut easy what causes the problem is the soft to hard interface. I have had bands doing the wave in knotty pine but rolled an oak log on and it cut perfect boards. This contradicts what most say but it seems to me too much set in knotty pine does not give the back of the band any guidance and leaves it free to dodge and dive around knots. Frank C.
