A question about Mobile Dimension edger belts
Started by Wes Lyon, April 11, 2015, 02:49:34 PM
Wes Lyon
Does anyone have a picture of how the mobile dimension sawmills make the edger shafts turn?  As i recall it was a v belt setup on a multiple groove pulley turned 90 from the main shaft.
If anyone has a picture or example i would sure appreciate it.
Wes
hacknchop
I dont have a pic but have changed tons of them anyway the belts usually consist of 3 doubles put them on main shaft first  then turn them counter clock wise so that both the main saw and edger turn the same way then lift  shaft up and put your top edger bearing bolts in then the bottom now  put the bolts back in on the mandrel (main shaft)tighten your belts set your lead, put the vertical roller back on so that it bearly touchs edger belts put guard and stuff back on.Hope thi helps.
Often wrong never indoubt
