Being Flexible with your Sawmill business
Started by just_sawing, April 07, 2015, 07:42:10 PM
just_sawing
I have been operating a Sawmill for close to 22 years here in Middle TN. One of the key things that I have learn is flexibility in the work model.
When we bought our dream home four years ago I big eyed a lot of the woods here. Meaning I saw the big trees and did not notice all the small stuff that was in the way. The timber that I am concern with is Red Cedar that is from 4 to 8 inches on the small end. Yes there is a market but it is by the ton and a good way to go broke and I run a Sawmill not a logging operation.
This timber will not mature in my active life time so I was presented with a problem. The solution came from a friend that has a customer that needs split rail fencing. I am now in the rail business with one of the only 10 foot rail splitters in this area. It appears that this may be here permant
You can follow me at
www.http://haneyfamilysawmill.com
Peter Drouin
I like that. Good luck. 8) 8) 8) 8) 8) 8)
A&P saw Mill LLC.
License NH softwood grader.
samandothers
Way to react to what was available and had a demand!
dustintheblood
That's perfect!  I like the setup.  Just paint your splitter orange and sell the patent to WM.  Let's call it the PS9000   :D :D
Case 75C, Case 1494, RangeRoad RR10T36, Igland 4001, Hardy 1400ST, WM LT40HD, WM Edger, ICS DH Kiln
YellowHammer
That's really something.  What does a split cedar rail sell for?
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
hunz
I know the 10' locust split rails get $9ea. Ask me how I know how, and I'll direct you to my empty bank account. The local splitting man really loves me!
Dream as if you'll saw forever; saw as if you'll die today.
2006 Woodmizer LT40D51RA, Husqvarna 372xp, Takeuchi TL140
4x4American
Boy, back in my day..
Cedarman
We sell  a 10' rail quartered from a 6" log for $4.75 each.  We also split rails from sassafras.  Sold over 10,000 of them to Lincoln Boyhood Memorial.
JustSawing, I too am curious what you get for your rails.
Is your splitter just a 2 way or can you split 4 at once?
ozarkgem
how about some close up pics of your splitter? Nice looking rails.
Jemclimber
Quote from: Cedarman on April 08, 2015, 06:36:23 AM
Judging from the wedge with what appears to be 3 way placed at 120° apart I would say it splits 3 at once.  Maybe hard to see on your screen.
I have family in Sante Fe, TN, not sure how close that is to you, but it's a beautiful area.  Nice operation just_sawing.
lt15
just_sawing
We have switched to a Single Blade on the wedge because we are in larger logs. We get $9.00 as of now for the rails at 10 foot. Our rails are averaging 1 ton per fifty in a bundle.
We loaded the trailer rated for 36k and had 47k on it. They are heavier than thought.
just_sawing
4x4American
Gonna have to edit your handle now to include splitting too :D
pine
Did you build the splitter or acquire it?  What is the drive mechanization for a 10 ft wedge?
That is meeting a niche market head on.  My admiration to you.   smiley_thumbsup
Dave Shepard
Not sure how that splitter is powered, but this is how I'm going to power mine:
just_sawing
Had a Mennonite welder friend weld the beam (It was 3 by 8 tubing totalling 8 pieces.) Then I welded then rewelded then rewelded more modifications. We are close to what we want on this one. I am powering it with a 12 horse and a 16 GPM Pump. I advise to go as big as you can for your power.
Cedarman
We made an 11' splitter using a 2' stroke cylinder.  We have a straight wedge at end that we can put a 4 way on or bolt a 6 way if the logs are 8 to 10".  The pusher plate is at the end of the cylinder.  The whole cylinder slides along the I beam.  We put a pin behind the base of the rear of the cylinder holder each time we push the cylinder forward.  Takes a little longer than if the cylinder were 8 or 10' long.  When I first built it, I only planned to split a few hundred rails.  Probably have split 20,000 by now.  Use a MF 2165 for power.  Wife gets to set in the seat using the controls as the heavy lifters do their work.
pine
Quote from: Cedarman on April 10, 2015, 06:23:11 AM
Thanks for that. :)
That is what I was asking just_sawing because I did not see anything like that in his picture.
Dave Shepard, you have a good size cylinder but still does not look like a 10 ft actuator. Are you going to so the same? Is there any kind of design that can avoid the reposition of the cylinder base pin?
Dave Shepard
It's about 8'. I'll do a sketch of my intended setup when I get to a real computer.
Dave Shepard
To get the length of stroke I need, I think I will use a two stage pusher. The log goes on the first stage to start the split, then you retract the ram enough to drop to the second stage. I'm not sure if there will be a problem with the log being stuck on the wedge and not dropping. For locust posts/rails, it may be as simple as manually pushing down on them. For splitting logs, you might have to push down with a loader or something. For high production of posts, this would be used in conjunction with a small log loader with a grapple.
just_sawing
Just came in for a breather. Here are some better [pictures of the setup
Brucer
Sometimes the simple solutions are the best.
I'd say a couple of supports spaced out past the wedge will help your helper ;).
Bruce    LT40HDG28 bandsaw
Yup, those multi-stage pushers are serving well.   smiley_thumbsup
