What's up with this guy?
Started by GATreeGrower, March 27, 2015, 05:11:53 PM
GATreeGrower
Wow.  There is a lot going on there.
clww
That one looks like the Elephant Man.
Many Stihl Saws-16"-60"
18-Wheeler Driver
WV Sawmiller
Wow! I thought totem poles were carved, not grown.
Clark
Let me be the first to ask: what would that look like cut up into lumber?
Clark
SAF Certified Forester
mesquite buckeye
There are lodgepole pines in Yellowstone that look like that. Some of the buildings around Old Faithful have incorporated them in the beams and guardrails, etc.
If trees feel pain, that is a picture of misery.
Warped
These cut wavey, unless you use Compound W in the coolant jug......
Good with the rough stuff and rough with the good stuff
I would never saw that tree into boards.  I wish it was mine, I would remove the bark and use it as a signature support column in the cabin I will probably never build. :D
Warped
Quote from: Jeff on April 01, 2015, 10:37:55 AM
That would certainly make a sweet centerpiece.
