Logs
Started by Peter Drouin, March 26, 2015, 09:39:10 PM
Peter Drouin
I have an open door so to speak where guys bring logs in and I will buy from them.
Some good, Some short, :D
15' 7" ::)
7' 10"
The 15' will be scaled at 14' and the 7' I don't pay for. :D :D
But most times he dose OK.
I think it's good to have tree serves guys and excavating guys bring logs in. Just a few logs in at a time.
And with the roads posted I can still get wood.
A&P saw Mill LLC.
License NH softwood grader.
They need a new measuring stick.  ;D
Some folks just truly do not get it.  Of course I do not buy and I will pretty well saw anything, but it is hourly rate when anything less than 8' goes on the sawmill.
POSTON WIDEHEAD
Get'em any way you can Peter. Theres a market for 'em all.  :)
Peter Drouin
Quote from: POSTONLT40HD on March 26, 2015, 09:55:04 PM
Getting the logs from them is not the main thing, Them telling I'm here to the public is the goal. ;D
I get logs this way.
;D
A&P saw Mill LLC.
red oaks lumber
wow, your snow melted fast and the dust came early ;D
Ron Wenrich
I scaled logs for a large mill, and scaled all the incoming logs.  I had one guy bring in a whole trailerload of logs that were cut 15' 11".  Paid for 14' logs with an explanation of why.  Told him to look at his measuring pole.  A lot of guys use an 8' stick.  Eventually, they start nicking the end with their saw, and it becomes short.  Never had a problem after that.
Dave Shepard
Peter, you just had to rub it in, didn't you? :D
Rougespear
What is the common length of over buck on a log?  By that I mean if I want 14's (or at least to get paid for 14's) how much extra length you to guys commonly buck them at?  Is 14' 2" enough to handle the eventual checking on both ends?
Custom built Cook's-style hydraulic bandmill.
Dave Shepard
5" or 6" is the norm around here. On 16' and longer I like a little more, 8" or 10", so I can cut boards down if I need to.
Ron Wenrich
For hardwoods, the typical trim allowance is 2" on a well bucked log.  I may allow a little under that, depending on the quality of the log.  For ties, we need 8" since the finished tie gets trimmed to 8'6".  So, if you brought in a log under 8'6", it's not going to be tie quality.
Peter Drouin
Quote from: Dave Shepard on March 27, 2015, 09:49:37 AM
What rub, Just tell everyone you see you want logs and wave a pile of cash around.
You will have guys coming from all over. :D :D :D :D :D
A&P saw Mill LLC.
Peter Drouin
Quote from: Rougespear on March 27, 2015, 11:09:46 AM
I like 6", No more or less. I want to just look at a log and know what it is from across the yard. I don't want to have to trim the logs and have buttons all over. :D
A&P saw Mill LLC.
I like to see them 6"-8" over.  That way if the log has been skidded and the end is dirty, I can have the customer to knock an inch off.   ;D
4x4American
6" of trim is what I like.
Boy, back in my day..
hacknchop
I agree with the 6" or more for trim and have always paid for what I get if I wasnt going to saw it up then I simply suggested the logger or whoever brought the logs into my yard had a month to come and get it or it went on the slab pile.I would saw anything over 6'but under  8'into 6"fence boards.
Often wrong never indoubt
Peter Drouin
Quote from: hacknchop on March 27, 2015, 11:49:40 PM
With all the short stuff I cut in to 4x4 for blocking.
How often when you load a trailer with the customers lumber and watch your 4x4 or 2x4 go and never be seen again. :D :D :D
A&P saw Mill LLC.
Ron Wenrich
I know of a couple of mills that charge for those extra pieces of blocking.
Rougespear
I like the idea of cutting shorts into 4x4 blocking... it always finds a use.  I just made up a level pad with some 6x6 yellow/ponderosa pine and those things are HEAVY.  I'd rather have had to stack a couple 4x's on top of each other instead.
Thanks for everyone's thoughts re: bucking length.
When I sold logs to a sawmill,6 inches was required.
Larry
You guys are all on the sawmill side.  Ask the logger and I bet most like 2" of trim.  Never give an inch.  (old saying)
Peter Drouin
Sometimes Larry, the cut is 6" and goes to 2" trim. Way out of square.  :D :D :D :D  /
A&P saw Mill LLC.
Dave Shepard
Quote from: Larry on March 28, 2015, 06:56:08 PM
Rarely would that make a difference. You aren't going to gain another 2' of log, (or 1' in hardwood) by saving four inches.
A spec sheet from a mill is kinda like a manual on a piece of equipment. Both can save you money,IF you read them and do what it says.  ;)
barbender
4" on bolts (8'), 6" on logs is typical here.
