Log Grapple Fail
Started by kiko, March 25, 2015, 03:06:40 AM
kiko
Outer grapple tong pin boss should look like......
Instead it looks like...
snowstorm
jwilly3879
Did anything or anyone get hurt?
Good reason to stay away when the loader is working, I've had a pin break on the grapple cylinder and drop a log.
smwwoody
Looks like you have a little welding ahead of you.  I had a barko grapple break like that. Built a new boss out of sch 80 pipe and welded it back up. Had to hone it slightly to get the bushings to fit but it worked good
Full time Mill Manager
Cleereman head rig
Cooper Scragg
McDonugh gang saw
McDonugh edger
McDonugh resaw
TS end trim
Pendu slab recovery system
KJ4WXC
kiko
bushmechanic
Bushing failure or burned up from greasing?
kiko
I think 10000 hrs just did it in.  It certainty was not from lack of grease. Had to to cut out rod end pin for Cly as it was stuck.  The tong is off to the machine shop.  While it is down we will reseal and bush both the Cly , reseal the swivel and replace all the pins.
Maine372
just file up the remaining side and use it like a pulp hook!
