New Toes
Started by homesteader1972, March 11, 2015, 08:51:17 PM
homesteader1972
 Hello All,
Since the last post asking questions about adding hyd toes to my mill, I did a little studying on hydraulics and figured out an inexpensive way to add them. I got the hydraulic leveling system off an old Winnebago. It came with four hydraulic cylinders, the valve, hoses and the 12volt pump and reservoir. I was able to make it work, and it works well, not to say a lot better than the manual ones. I was wanting to get the valve into the factory hyd box, but it just would not fit. So it had to go below the box.
I did have to get three hoses made, and had I shopped around I could have saved about $50, but the whole thing cost me about $300.
This is where I was able to tap into the hyd manifold. The one in the foreground is the pressure side, the one in the back is the drain to the tank.
This is where I mounted the valve. I has four valves, but I'm using two. It sticks out a bit more than I would like, but this was all I could come up with that didnt require alot of fab work. That bracket is the only weld on the mill.
Here is one of the cylinders. The spring return is not as fast as a double acting cylinder, but again, it works great and is much faster than manual.
Here is the finished guard for the valves. Sorta ugly, but strong and should offer protection.
This should hold me well until I decide if I really need to upgrade my hydraulic system altogether. Other than cutting the slot in the hyd box, and a few drilled holes on the mill, it required little in the way of cutting or drilling.
Thanks for previous info.
Woodmizer LT40HD20G
YellowHammer
That's using your head.  Great idea.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
ncsawyer
Very nice work!  Is your mill a manual mill with hydraulic upgrades or was it originally a hydraulic mill?
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
slider
nice job .you may want to consider adding rollers to that.They make things much easier when moving big stuff on the mill.
al glenn
Ga Mtn Man
Nice job.  Now you'll have to paint the rest of the mill.
fishfighter
I like it. I will have to try and find a set up like that.
Are those RV leveling jacks?
homesteader1972
Thanks for the kind remarks.
Ncsawyer, my mill came with hydraulics, but had manual toeboards.
Magicman, yes they are RV leveling jacks.
Ga Mt Man, I'd like to paint the entire mill, thinking of doing it sometime this summer if there is time for it. It would not look so "old" when sawing for others. I hear from time to time, "wow, that cuts really good for such an old mill"
Woodmizer LT40HD20G
tmarch
Quote from: homesteader1972 on March 12, 2015, 07:03:16 PM
That's EXPERIENCE ya know. :D
Retired to the ranch, saw, and sell solar pumps.
Percy
Homesteaders first name is McGuyvor :D
I love stuff like this....
Percy
Chuck White
I want to add a little more spring to my toe boards.
Sometimes I end up having my offbearer push them down while I operated the down lever.
MartyParsons
Hello,
Chuck the toe board on the early mills with springs pulling the cylinder down. Most times the seal gets stuff behind the seal. Replacing the seal will most times fix these. When you remove the seal clean with a round wire brush on a drill. Might be a inexpensive fix.
Marty
Spring part # P09742  $ 7.02
Seal Part # P09740    $ 8.50
Chuck White
Thanks Marty!
I usually try to keep the area around the cylinders clean and a little lube on them too!
johnjbc
When I had Woodmizer do a tune up on my mill a couple years ago the tech suggested removing the spring that returns the Toe Board valve to the center. Now if I turn it to the down position the weight of the next log will push the Toe Board down.
LT40HDG24, Case VAC, Kubota L48, Case 580B, Cat 977H, Bobcat 773
Chuck White
What I was getting at was that if there was no weight on the toe-board, it would sometimes not go down.
They always go down if there is a log sitting on them!
johnjbc
Chuck
Sounds like yours has been modified already. Before the change I had to hold the selector and push down at the same time. And if I forgot It sawed these NICE LONG WEDGES. :D
Chuck White
John, I was talking about the actual toe board, not the operating handle!
It would always go down when the lever was pushed down when there was weight on the toe board, but if there wasn't weight on it, sometimes it wouldn't go down on it's own.
johnjbc
 ChucK
Mine worked the same way before the change. But I had to hold this valve until it was down. Now I just put it in the down position and it stays there. When the log pushes on it it goes down.
