Trade?
Started by Peter Drouin, February 26, 2015, 12:23:27 PM
Peter Drouin
I have a guy wants to trade even for my JD 690 unknown Hrs run very well and is tight.
1988
For a 2005 990 JD with a 1000HRs on it.
It has a 40Horse Yanmar in it.
What do you think?
A&P saw Mill LLC.
License NH softwood grader.
Bruno of NH
That's a nice tractor but it's always nice to have a excavator if needed .
Jim/Bruno
LeeB
Tough choice. The tractor is nice and the back hoe attachment would make it even more handy. I think I would keep the big boy though.
whitepine2
 Seems like a fair trade but it all depends on what your needs are
and what will give you the most and best use.
Dave Shepard
If Big John is tight and dry and functional, I'd keep it. Not that the trade is a bad one, but unless you have a lot of light landscaping planned, then John and Big John should have everything covered.
Corley5
I think I'd keep the excavator :)
Autocar
Iam with Corley I would keep the track hoe !
Bill
sprucebunny
A quality excavator in that price and size class is much harder to find than a tractor with those attatchments and specs.
JMO
landscraper
Another smaller tractor will just do the same kind of stuff as your big tractor, only slower and less of it.  Although they are ok for occasional use, a backhoe attachment is a poor substitute in all regards for a functioning excavator.  If you got rid of the excavator and then still needed one from time to time think what it would cost to hire or rent one.  Dollar wise I'd say the deal is a tad in his favor too, a 690 of that vintage in good running condition would bring about $16K to $20K around here, the unknown hours would put it on the lower end.  The backhoe attachment, tractor and scraper blade together is worth $14K to $16K tops in my book.
Firewood is energy independence on a personal scale.
21incher
I would say keep big john and buy a cheep compact with a loader if you need it. That little tractor would most likely have a hard time moving those logs that big john is tossing around.
GDinMaine
I think the price is quite comparable. That JD tractor is right in the $20k range around here. It really depends on what you want to do. If you only run the excavator 10 hours a year, then you might get more use out of the tractor.
It's the going that counts not the distance!
WM LT-40HD-D42
Peter Drouin
Well, the rest of the story. I had put the 690 on CL with no calls 25,000.00 Or best offer.
I'm looking for a 1044 lull. The 1044 will lift 10,000 lb and that's handy to lift a 45' log and reach over lumber to get lumber. This guy is clearing land and can use the 690.
So, I thought I can sell the 990 JD for maybe 20,000.00. Kind of get the 20,000.00 in a round about way.
I use the 690 only 2 times in 2014.
A&P saw Mill LLC.
Brucer
My 33 year old JD 750 has a 3 cylinder Yanmar diesel and it's still going strong :).
Since you were planning to sell the excavator, you've obviously given a lot of thought to how much you really need it. If the tractor you figure you can use the tractor more, I'd say go for the trade.
Bruce    LT40HDG28 bandsaw
Dave Shepard
I'd just about rob a bank to get a LULL. :D
shinnlinger
I had an '84 690B and I loved it but at a certain point you get done with most of the stuff you need a big excavator for and my neighbor had to have it.  We made a deal and I even get it back on occasion which makes seller remorse pretty easy to deal with.  The JD tractor is a nice machine and a lot more versatile and the hoe might be handy but after the 690, a tractor mounted hoe will seen insignificant but it sounds like your looking to sell.  I have a hard time believing you would get 20k for it though.
I had a big Lull up here building my house and it was pretty handy to have around too.   I could have bought it for a decent price but just couldn't justify it .  Last I knew the brakes went out on it and  it is just sitting.  I think it was also an 84, with a 99 duetz engine but think it was the 840 Highlander.   It was a 4x4 and had the stabilizers on the front and could reach 45 feet or so.  Would you like me to inquire on it's availability?
Dave
Shinnlinger
Peter Drouin
Quote from: Dave Shepard on February 26, 2015, 08:16:23 PM
Me too, but I like my freedom  :D :D :D :D
I have looked at the off road forklifts. But they don't reach out like a lull. And in the off season [winter] I know I can work it on a construction site . Or use it to pile snow 40' high. :D :D :D :D
A&P saw Mill LLC.
Peter Drouin
Quote from: shinnlinger on February 26, 2015, 09:04:43 PM
Dave
Can I get a rain ck on that? I do have my heart set on a 1044 with a John Deere motor.
And 20,000 is a lot, But I have to start somewhere. I will miss the 690c.
A&P saw Mill LLC.
shinnlinger
Ok,
But here are some action shots.  He repainted it since these were taken....
Shinnlinger
DDDfarmer
Guy was trying to sell a 690 here last summer for 4-5k needing pump work.  I think it went for scrap.
Treefarmer C5C with cancar 20 (gearmatic 119) winch, Husky 562xp 576xp chainsaws
Peter Drouin
Quote from: shinnlinger on February 26, 2015, 09:24:13 PM
Ok,
YA, that's a nice lull a 844 is good for 8000LB.   Thanks
A&P saw Mill LLC.
uplander
 Kind of depends how much you need to dig. Anytime I was around one of those 690's I always noticed how slow they were. For my use I would do the trade. The tractor is a lot more versatile.
Woodmizer lt40G28.  A kubota L4600 with loader and forks.
Various Stihl saws and not enough time to use them!
Finished my house finally. Completely sawn out on by band mill. It took me 7 years but was worth it. Hardest thing I have ever done.
Dave Shepard
He's not going to use the tractor, he's going to sell it to buy a LULL. ;)
drobertson
always seems to be a close play at home plate ;D  If you only use it twice a year, then maybe do the deal and get what you are needing.
Easier said than done, but once it's over then you will have what you've really been needing.
LeeB
The tractor might be easier to sell.
Hilltop366
Quote from: LeeB on February 27, 2015, 11:26:02 AM
x2
I'm thinking I could sell 10 tractors like that before anyone would look at the excavator.
Of corse someone will call wanting to buy the excavator right after you trade. ;D
