Gluing a puzzle down
Started by Qweaver, February 11, 2015, 08:59:50 AM
Qweaver
We'd like to permanently mount a completed puzzle onto plywood.  I considered contact cement.  But how would  I coat the back of the puzzle?   How about a heat activated glue?  I know nothing about these.
Forget it.  GOOGLE solved it.
I've done that a couple times,but never on plywood. I went to a craft store and put some sort of special glue on it. This would be the picture side. Than I mounted it to a piece of cardboard to mount.
So Qweaver,  what did you find?
Cedarman
40 years ago, I made a huge puzzle that took months to put together.  It was about 3' by 5' or so.  We placed in on a sheet of plywood and there was a special spray that you sprayed the puzzle and made it stick to the plywood.  We then hung it on the wall.  So there must be a special spray out there that will make the puzzle stick to the plywood.  Knowing they make it  gets the problem 1/2 solved.
shinnlinger
Wife bought some special glue intended specifically for that purpose.  I will ask her how it works.   I think you brush it on surface and it dries clear but holds it together so you can then mount it.
Shinnlinger
Buy some stuff called Mod Podge at your local craft store.
Here is a puzzle I restored that hangs in our bathroom.
Restoring another logging themed collectible.
Remle
Wow, this is a day late. But the object appears to be to conserve it for your viewing pleasure hanging on a wall. It's only conserved by not gluing it to any thing, just put it into a picture frame as you would any picture. Just replace the paper backing with 1/4'" plywood, the glass and a plywood backing will keep it together.  If the frame comes with a mat border trim the inside of it to the picture dimensions.
