Another Reason to Own a Sawmill...
Started by Ga Mtn Man, February 10, 2015, 08:21:17 PM
Ga Mtn Man
The lube jug makes a dandy water level:
;D
drobertson
Yep, hillbilly engineering at its finest! ;D  whatever works, right?
47sawdust
The nice thing about a water level is you can go around an entire building from one spot if you have a long enough hose.It is also not light sensitive.Windshield washer fluid helps to make it more visible and for those of us in freezing temps. that is mandatory.
I still like my dot and line lasers and haven't used a water level in some time,but they do the job and cost close to nothing to put together.
Mick
Cutting Edge
Quote from: drobertson on February 10, 2015, 08:26:53 PM
x 2  Pretty slick thinkin' right there   smiley_thumbsup
"Winning an argument isn't everything, as long as you are heard and understood" - W.S.
Cutting Edge Saw Service, LLC -
- Sharpening Services
- Portable/Custom Milling and Slabbing
- On-Site Sawmill Maintenance/Repair Services
Factory Direct Kasco WoodMaxx Blades
Ph- (304) 878-3343
4x4American
You oughta contact the sawmill MFG's and tell them to put that in their brochure cause if I didn't have a sawmill and they told me that I would almost have to buy one   ;D
Boy, back in my day..
