STIHL 039:suggestions?
Started by Buzz-sawyer, August 25, 2004, 12:06:32 AM
Buzz-sawyer
Ol' Buzz needs some guidance  8)
on a 039 I was given....freed it up, but needs main bearing.....I neeed a pull start-side cover, bar and chain.....you know what will fit it and interchange....I was told 310 would, thanks all. ;)
if anyone has parts Im huntin em :)
    HEAR THAT BLADE SING!
DanManofStihl
You might want to ask your local dealer what parts are interchangeable You should try ebay for the parts you could just get a saw for parts on their and build one that works from the twos parts I did that with an 066 and it works great now.
Two Things in life to be proud of a good wife and a good saw.
Striker
When you get that 039 running, open up the muffler and make it roar.
SasquatchMan
I'm not sure, but aren't the 039, 031, 029 similar in all but bore, or is that just the new 290/310/390s?  There should be lots of dead 29s around...
Senior Member?  That's funny.
Buzz-sawyer
I think the 029 039 310 and a couple others have the same bore .....i.e same replacement parts for jug and piston......Im not sure if the plastic will interchange???
