OWB to heat kiln?
Started by xlogger, February 06, 2015, 06:59:53 AM
oakiemac
I just started using a wood boiler to heat my kilns.
works good until the outside temp drops below 10 degrees then the boiler struggles to heat the shop, lumber bldg., and both kilns. My boiler is home made so not as effieceint as some others. I have the water temp. set at 175 degrees. Might bump that up some.
@Billikenfan,this is how to put a picture in your post. Got any of the OWB? I burn alot of junk wood in my OWB to heat my house.That is why I brought it. I burned almost all softwood in it for 2 years steady.
I like to go to whatever post or start a new topic first to include a picture.Go to your gallery,it will open in a new window.Click onto your album,then click onto whatever picture you want,it will get bigger,than scroll down a little to find,Insert Image In Post,click onto that,click Yes and that is it. Some have to copy/paste the link to work.I like to hit the enter key at least once or twice to move the picture down away from what I am typing. The enter key really helps to leave some white space if posting more than one picture. Use the preview button to see how it looks and modify it if needed.
xlogger
How do you try to heat the kiln, with a heat exchanger or just let the water run threw a few pipes with a fan inside the kiln?
Ga_Boy
I used aluminum finned copper tubbing.  I ran four 20 foot lengths of the finned tubbing and the fans blew the air across the tubbing to heat the air.  Some mount the fans to radiator type heat exchangers.
xlogger
Getting ready to start building the Kiln. Going to be 14 ft long to hold 12 ft lumber. Mostly going to kiln dry 8 or 10 feet.
Now a few questions.
If I pour a concrete floor and put insulation under the slab will that work
or should I just build it on a wood floor alone with maybe using 2x8's?
Was thinking about 8 ft high and 8 ft wide. Do you think this is plenty of walk behind room to get behind a 4ft stack of room
with some kind of pipes and blowers?
WDH, didn't look like you put in a walk in door, I was thinking I should have one, what you think on that?
Ga boy had Aluminum/copper pipes, how do you think pex pipes would work with a couple fans behind it or how many fans in 14 wide kiln?
Wonder if pex pipes in concrete floor would heat hot enough if I did pour a slab?
I did  plan on putting a DH in there also.
Ga_Boy
Regarding the heated slab; I think this has been discussed before and for a reason that I do not remember was determined not to be a good approach for a wood kiln.  It may have been something about the time required to raise and lower the temperature.   Heated floors are for consistent heat over time by not ideal to raise or lower the temperature 10 degrees in  a few minutes.
The pix tubing is a thought for a heat exchanger.  Check with you local HVAC guys, they may have a source for a water to air heat exchanger that is not cost prohibitive.  For fans, you will need at least 2 with 3 being better.   I used a 20 foot insulated shipping container.  The door seals were excellent, it made a very efficient kiln chamber.  Used a powered exhaust fan to dump hot and humid air when needed.
Drying wood is all about the ability to precisely control the temperature and humidity and to raise and lower the temperature or humidity in a short time frame measured in minutes.
xlogger
Thanks Mark, I know I have lots to learn on the controlling the heat end of this. I was thinking if I could put the pex in the floor it would be out of the way and I still could rig it up with the fans at the top pulling the hot air up and pushing it around the pile of wood. That was just an idea I wish it would work but probably have to run the lines like you did yours. I still need to see if I can find a thermostat that will control the water flow hook up to a 3 way zone valve in the water line. If any of you with using a boiler for heat how do you control the water temp?
xlogger
I google thermostats and found an old topic here that Dave Sheppard found a thermostat on QC Supply. Dave if you see this did you get the one there part# 20254 that shows going to 220°? Its digital and that what I would like if it did work for you.
@xlogger,2 ways to contact a member,one way is put an "@" in front of a members name. This will bring them to a post as I did with you. The other is to send them a Personal Message,PM. @Dave Shepard please see the above post.  Should be a ballon below each members user name to PM them.
I find that it is a good idea to check the load in the kiln each day.  I also need to fill the wet bulb reservoir each day as well.  So, I open the doors each day just enough to check the load and fill the reservoir.  There is not much heat loss at all as the doors are only cracked open, and the wood in the kiln is a huge heat sink.  The temp comes back up to the pre-door opening level quickly.  Also, when you open the door, you are venting water vapor from the air in the kiln.  The whole point is to get the water out.  So, on a small chamber like you are building, another door is not that important, and it is another thing to build and seal.
I would make sure that you have at least 30 - 36" of free space in front of the load and in back of the load for good air exchange.  If You are only putting in one stack of 4' wide lumber from a depth standpoint, I believe that 8' is not enough depth.
xlogger
Thanks, that's the kind of info I need to know, so maybe 10 ft wide?
Ga_Boy
The environment in a kiln is harsh, high temp, high humidity with wood acid in the humidity.  The wood acid will and does eat most items.
I mention this so you know to buy components that will withstand the harsh conditions.  I used sealed conduit and light switch housings and still had to replace light switches every few months.
Most standard off the shelf items will be eaten in a kiln.
Dave Shepard
Quote from: xlogger on March 12, 2015, 07:10:32 AM
I never did by a thermostat. I was trying to build a kiln using science and proven technology. The person I was working for at the time was trying to build a kiln using cheapness and idiocy. He won the fight, but lumber quality lost the war.
Xlogger,
I believe that my chamber is about 10'4'' wide.  However, I have the Nyle L53 Dehumidification unit in the back of my chamber on a table, and it is about 16" deep which leaves me about 24 to 30" from the back of the load to the dehumidification unit.  The Nyle plans call for a minimum of 12" from the load to the unit, but I feel that is a little to close.  I added more room due to input from Yellowhammer when I went to see his kiln.
xlogger
I need to ask a question about the vents. If you keep your DH running do you still need them? I know I have lots to learn about drying but need to get the kiln build correct first. I've got some 2" cedar slabs that I need to get started on first.
GeneWengert-WoodDoc
Vents can often remove more moisture per hour on a sunny day than a DH can.  So, it depends on the DH size and how much you want to spend for electricity.  Venting is free.
If you want a DH kiln, then it is probably wiser to skip the solar part and insulate the structure fully.  Drying is faster and less expensive than with solar.  That is, a  VT solar kiln works well when the sun is shining, but is not energy efficient when it is dark.  High heat losses at night mean expensive DH operation.
xlogger
Gene, I am planning on insulating the whole kiln. Probably going to need a book on drying. A while back you suggested one, I think you wrote it. What was it again? I can put in a vent, what would you suggest? We might level for the pad next week I hope, so I need to make sure I build the structure correct after that. So far I'm planning on building it 14 ft long, now 10 feet deep after some suggestions here and thinking I might go 8 ft tall with swinging doors to load with forklift. I'm thinking that mostly I will have in it is 8 ft lengths but though that I would be sorry later if I built it that short. Also the class at VT on solar is coming up, not sure I will go now since I'm not going with a solar kiln. Would that be much help with what I'm doing?  Thanks, Ricky
GeneWengert-WoodDoc
Nyle does sell plans, or perhaps someone here has a set.  No sense re-inventing the wheel !
Drying Hardwood Lumber is the best book on hardwood lumber drying.  Out of print, so download it and print it.  Actually a copy store like UPS can download, copy and bind it.
There are likely several classes in the next five months specific for DH, like the one in WI in August that would be better for your needs.
oakiemac
xlogger, how many board feet will your kiln hold? If you are looking to use a DH unit, I have a nyle L50 which I think is rated for about 1000bf. I bought it used and used it for a while but now its been in storage. If you are interested let me know.
My 2 working kilns now have a Nyle 200 and an Ebac in them but neither is working so I use them as conventional kilns which surprising enough work just as well as the DH.
xlogger
Probably will not have over 1000 bf ft in it at a time but it should hold more. My plans are to build it to hold 12 ft long but mostly 8 ft will go in it. I'm getting lots of good advise here. As of now I think my plan is to build it like I was planning on when I started and just use heat from my OWB to heat it with maybe having a dehumidifier. I'll probably air dry good before I put wood in. I'll have the chamber built and I'm sure after I work with it and learn what not to do I'll make changes.
4x4American
Boy, back in my day..
GeneWengert-WoodDoc
Appreciate that the difference between DH and conventional is a hardware difference mainly.  Given the same temperature and RH in the kiln, both will dry at the same speed and with the same quality.  The big difference is in costs...capital and operating costs.  Plus some conventional kilns can get really hot (180 F) which means fast, and some DH units can run at 90 F which is hard to do with many conventional which means possibly higher quality with thick, green species like oak.
