Another QS oak question
Started by JMoore, January 29, 2015, 08:30:05 PM
JMoore
 I have not QS an oak log yet but will soon. I read on a post the other day that there are certain things to look for in the end grain to determine whether its worth QSing or flat sawing. I figure I have a mill and I pretty much only want to build my furniture with quarter or rift from here on out. I just love the way it looks. Thank you for any insight!
scsmith42
From a stability standpoint (as well as wood movement), any QS lumber will be more stable than FS.  It will all have vertical grain as well if you take the time to center the pith in your logs in both directions.
From a ray fleck standpoint, you want to study the ends of the logs to see how the medullary rays are running, and orientate the faces of the quarters to be as close to parallel to the rays as possible.
Tom's 3638D Baker band mill
Larry
What he said.
After studying the rays for a while you will notice some oaks have nice fat juicy rays while others are skinny things. The fat ones make for the best figure.  Some species of oak seem to have those nice rays more than other species.
Also look at the rays from each end of the log as that will also add to your education.
4x4American
subscribed.
You coulda asked this in the fancy sawing thread!  Keep all the fancy stuff in one place!
Boy, back in my day..
5quarter
Ditto and ditto. Also, make sure the rays run fairly straight from the outside to the center. if they sweep to the center in a curve, expect the best figured boards to be spotty at best.
Another funny thing about QS oak; with each pass of the planer, you change the figure. sometimes you will look at the end grain of a board where the rings are exactly 90° to the surface yet the ray fleck is hardly there. a couple passes through the planer and as you cut into the next ray, the whole board comes alive.  8) 8)
Blue Harbor Refinishing
JMoore
 Thanks to all that's what I was looking for. 4X4 I didn't want to highjack someone's thread.
terrifictimbersllc
Can also cut parallel to the tiny cracks that are everywhere, these are sometimes easier to see than the growth rings. Romanian barrel maker taught me that.
scsmith42
Quote from: terrifictimbersllc on January 30, 2015, 06:59:10 AM
The "tiny cracks" typically are the medullary rays.
4x4American
terrifictimbersllc
Quote from: scsmith42 on January 30, 2015, 08:34:40 AM
Hey, no wonder it works!   Thanks!
Brad_S.
In my world, any oak over 20" on the small end gets QS regardless if what the rays look like.
