190 gearmatic problems on C7D Treefarmer
Started by jonesjco, January 24, 2015, 07:14:56 PM
jonesjco
I am looking at a gearmatic for a customer its a 190 on a treefarmer the winch has its own hydraulic tank and a piston pump that runs off the pinion in the winch to operate the controls instead of the master cylinder controller that I am familiar with. The problem with this one is that the pump will not pump oil it has 0 pressure, 0 flow, wondering if anyone else has had this problem. Parts for this winch are a problem. Paccar tells me that pump housing and the piston is no longer available i haven't removed the pump yet. If it is something simple i will take it out but if not I recommended to the customer that we remove it and install a 119 instead. I don't want the customer throwing good money after bad. Looking forward to any info I can get on this winch
Gearmatic: 9 little letters that spell big aggravation
lopet
I have seen conversions being made with belt driven pumps from the engine pulley. That will require a bit of tinkering but it can be done .   If you you have a 119 kicking around, that might be easier and quicker . Just sayn
