Now What!?!?
Started by JB Griffin, January 22, 2015, 07:22:28 PM
JB Griffin
My mosfet board came in tonite at 5:06pm 8) and I got it put on by the headlights of my truck, and.....no dice :'(.
Have any of you had the headrig not move until the speed pot is at half throttle or more and what was the cause?
Also my hyd. tensioner is not holding pressure, like losing 300lbs in 3 minutes, bad seals or low on fluid?
Sorry but I had to vent a minute, I only thought I was done with all these nit-picky problems, but have since learned better. :-\
2000 LT40hyd remote 33hp Kubota with 6gpm hyd unit, 150 Prentice, WM bms250, Suffolk dual tooth setter
Over 3.5million bdft sawn with a Baker Dominator.
Quote from: JB Griffin on January 22, 2015, 07:22:28 PMAlso my hyd. tensioner is not holding pressure, like losing 300lbs in 3 minutes, bad seals or low on fluid?
That is a simple fix with a rebuild kit.  It uses "square O" rings, so do not try to use standard O rings for a fix.
Here is a picture of my blown O ring.  The kit will have a new piston and everything needed for a complete rebuild.
Does your head move easily by hand after you remove a wire from your power feed motor?  (removing the wire removes the shunt (electronic brake) that the motor provides.)  If not you might have a splinter wedged somewhere or possibly a frozen cam follower.  I am just saying that there is always a possibility that it could be mechanical rather than electrical.
YoungStump
Does the head rig move smoothly and have the full range of speed once it starts to move or not? Just thinking that it could be that the dial on the speed pot is no longer aligned with the markings on the board, I know mine isn't, I'm thinking the speed pot on my 70 also has some travel before the head starts moving.
I know how frustrating little issues like this can be esp on a machine your not familiar with, and not just used equipment I've had my share of frustration trying to get the bugs worked out of brand new equipment.
Don't loose hope you'll get this thing running like it should before you know it. 8)
Echo Enterprises 45HD2 production series band mill, Cook's Edger, sawing mostly pallet cants, rr ties, and grade lumber.
JB Griffin
No obstructions on the track, head moves easy and smooth.
Don't really have full range of speed, it will speed up but not really slow down.
Magic, I figgered its just a bad seal in the tensioner.
Right, but use all of the kit and rebuild the entire unit while you are in there.
JB Griffin
jcbrotz
Did you have a looksee at the forward reverse switch? it could be the issue as well as or the pot. I just got my new one from fedex today. My pot has a dead spot in it my right speed ain't there when sawing frozen hemlock to slow then stopped then to fast. Keep a sharp blade and go for it :D. That was my fix for the last few days. and its been awhile since I greased my swtichs so I would bet they are worn ::).
2004 woodmizer lt40hd 33hp kubota, Cat 262B skidsteer and way to many tractors to list. www.Brotzmanswoodworks.com and www.Brotzmanscenturyfarm.com
GDinMaine
Quote from: JB Griffin on January 22, 2015, 09:30:59 PM
Magic, I figgered its just a bad seal in the tentioner.
It could also be a worn or improperly adjusted belt on the forward-reverse motor.  It does not quite sound like it but it's worth checking. When I bought my mill, that belt was shot and produced intermittent operation of forward movement. Reverse was OK.
It's the going that counts not the distance!
WM LT-40HD-D42
JB Griffin
I might have this figured out, I was on the phone with Mike at WM for 45min tracing this down and found a wire in the wrong spot causing the ground not to be constant, got all put back together and it worked but was jerky and then .... it quit altogether, I had run the battery dead while working on it and my battery charger is dead as well.
Gonna charge my battery at my buddy's shop and try it again. :-\
drobertson
welcome to the orange club,
JB Griffin
Thanks David
I charged the battery and... No power feed at all, Nothing.
Got to call WM in the morning. ::)
jcbrotz
Check the diode should only have continuity in one direction. Mine went bad and took out the board. Also have a look at the lights on the board to see what they are doing they help with problems My pot is going again or I have a bad connection as the input light goes out at certain spots on the pot. New one came Friday.
JB Griffin
The lights on the board are working as they should, input from the pot is good too. ??? I have no clue on this as wires ain't my friend sometimes.
JB Griffin
Does anyone know WM rates for a service call???
I'm at my wits end and I owe money on this thing and can't use it. help_me taz-smiley
Larry
WM has a service center close to Springfield.  Might pay to let them go over the mill for ya.
Call WM tomorrow AM.
JB Griffin
I done and planned to call WM Mt. Vernon in the morn. I just wondered if anyone knew what they charged.
pineywoods
Never dealt with wm Mt vernon, but I can tell you about the guys in Indy. Have a test light or voltmeter ready and call them. They are very good at troubleshooting over the phone.
4x4American
I agree with pineywoods, my friends lt40super hd he got used had some electrical issues when he got it, he called up the indiana boys and they told him just what to do to get it running right.  Good luck and stay strong, it'll come together.
Boy, back in my day..
JB Griffin
Yup, 45min on the phone w/ WM Indy got me 10sec of run time.
Something is wrong I just don't know what.
JB Griffin
Did I mention I really don't know what I'm lookin at, it just looks like a bird nest to me :D
4x4American
 :D :D
I hate electrical stuff!
I bought a 1988 gooseneck trailer this weekend, tried to get some of the lights working for the drive back.  Man what a pita that was I might just better rewire the whole thing.  The wiring is all sorts of cattywampus.  Did I mention that the previous owner liked scotch-locks alot?  :)
4x4American
Hey Happy Birthday by the way, you're now a quarter of a century old!
Don't think about the entire "nest".  You are only concerned with one wire at the time.
You sound understandably discouraged, but Indy can and will walk you through it.  Those guys are good and know their stuff.
JB Griffin
Yeah Magic, I know but I bought it to make a living with and haven't made a dime yet.
4x4 Scotch-locks ??? ???
