6x6 or 8x8 help
Started by yarnammurt, January 20, 2015, 10:13:34 AM
yarnammurt
I am putting together a log/ timber house. And can't make up my mind if I should use 6's or 8's for the walls. How much difference would it make on heating and cooling?  The walls will be stacked green and have rebar drove in through 5 at a time.
ATS 10" Peterson, 09 New Holland 4x4 TL90 with loader, 125hp White,2 2009 Kawasaki 610 mules,
bigshow
R Value:
2.54 per inch of softwood  6": 15R  8":20R  8" would give you just under a 2x6 insulated wall R Value.
.71 per inch hardwood: seems hardly worth even bothering if energy efficiency is in question.
The logbuilder I learned from (decades of experience), said a log of with a top diameter of 6" is as small as you dare go for any thermal performance at all be it R-Value or Thermal Mass.
I never try anything, I just do it.
Roger Nair
Bigshow, you overstated the R value of softwood by a factor of at least two.  Research values are found in table 4-7 in parenthesis.  12% MC are relevant for design value.
http://www.fpl.fs.fed.us/documnts/fplgtr/fplgtr190/chapter_04.pdf
An optimist believes this is the best of all possible worlds, the pessimist fears that the optimist is correct.--James Branch Cabell
Dave Shepard
That's what I was thinking. I seem to remember pine being 1.3 per inch.
BCsaw
I think if you stick to 8x8's, you will be much happier. With any type of log construction, it is always about thermal mass. The more you have, the better off you are. I have seen part time buildings use 4x4's, not very good in terms of warmth and strength. Inspectors like 8" as a minimum in my experience.
Inspiration is the ability to "feel" what thousands of others can't!
Homebuilt Band Sawmill, Kioti 2510 Loader Backhoe
Tinner
Quote from: BCsaw on January 21, 2015, 12:09:22 PM
+1
i have read (on the internet) 6" is ok up to the 45th.  And 8" north of that.
