advice on tj 450c tranny
Started by so il logger, January 14, 2015, 03:51:07 PM
so il logger
hi everyone. Im new to the forum and looking for some advice. A few months back i got a 95 jack 450c grapple. I have been working bugs out of it since. The issue im dealing with at the moment is the tractor has to warm up 45 minutes before it will move. But if i operate winch after 15 minutes of warm up it will take right off. machine has new charge pump and sealing kit. And has 260 psi at charge pump. I really appreciate any advice and thank you in advance
coxy
welcome to the ff  where are you at    my be oil to thick or sticky oil port :-\ my cat takes a while to move but I have 30 weight in it its like roof tar on a day like today
so il logger
Thanks for the reply. Im located in southern Illinois. Today it is 25 deg. It does it even in the 40s. I am running hytrans that is Allison c4 certified. That's what the local dealer recommended. I am really thinking a sticking valve as well. Its strange how winching in a foot or so cable allows it to move
coxy
how is the filter    is there a line that maybe kinked  does the tranny have a screen in side    the cats have one on the bottom of the tranny under a tear drop cover  don't know any thing about them just throwing out ideas  :)
so il logger
I replaced all the filters on the machine. it has a sump screen on bottom left of tranny I pulled it and cleaned/ inspected it. As far as lines they look ok. The charge pump growls until it gets warmed up but is carrying good psi. I drained all the oil from trans and replaced it with the recommended oil weight. after it warms up it pulls great. just seems that it must have something wrong with it by it having to run so long  ???
coxy
the charge pump should not make any noise un less there is a blockage some place  and by putting the winch in gear it may be bypassing it some how or it is making it build more pressure   I had a hydro pump push oil out of the vent and fill cap when it was cold  drove me nuts and found there was a line that was coming a part on the in side and was making to much pressure and making it foam up       when the oil was warm it was ok only when it was cold and the pump would make some strange noises till it got warm  maybe the charge pump is crap even if its new
so il logger
I thought maybe the pump was junk but shop said if its making that much psi its good. I also noticed that until it warms up it pushes fluid out of the winch control spool on front of winch and it is foamy. it has the t40 winch which I think is same as deere. I think I will like the machine if I ever get it where I can really use it. Guy that had it before just ran it he didn't maintain it like we would have.
treeslayer2003
so il logger
It has the clark hurth model # 13 7hr32420-6  It is 4 spd
treeslayer2003
hmm, never had a clark act that way........oldseabee could maybe help if he sees this.
North River Energy
Not familiar with that particular application, but if the pump is growling and foaming the oil, you might have an air leak/blockage on the suction side?
Also possible to have adequate pressure but marginal flow.
so il logger
any info is greatly appreciated. I cant find any exploded diagram of tranny on net. and its a new machine to me
kiko
The charge pump is sucking air.  The regulator is in between the charge pump and the torque convertor housing . There are gaskets and orings between each mating surface. This where you will likely find the suction leak as the pump must draw the suction through the regulator valve.  Also the regulator slides on the same studs as the pump if the regulator moved when the pump was replaced but not removed to check condition or replace the gasket towards housing you may want to check it out.  A suction leak will soon destroy the pump.
so il logger
The charge pump was recently replaced when i got the skidder. however the idiot that owned it before me didn't buy a sealing kit which is the gaskets and o rings that you reffered to. That being said I just bought the kit to re seal the pump and installed it. kit included 3 gaskets 5 o rings 3 springs and a steel clad rubber seal for pump drive shaft. No change other than boosted psi by 20 psi. Do you think pump is already shot? Thanks for all the help i appreciate it
so il logger
One more piece of info i forgot to mention. While the machine is warming up the gauge shows 260 psi. pump growls while cold but if i shift to fwd or rev the pump stops growling and psi drops out to nothing for approx 5 seconds. then growl comes back and psi shoots right back to 260. but still wont move until it gets really warm.  :-\
so il logger
Well im pretty confident that its sucking air. Now gotta find out where
kiko
If it is not around the trans pump or regulator, then it is internal piping.
so il logger
Is it common for internal piping to leak? I thought about pulling trans valve body tomoro and checking for stuck valve or broken spring. If i was to way overfill the trans i could troubleshoot the internal piping right?
so il logger
I am going to take pic of the 450 tomorrow and hopefully figure out how to post the pic on here.
CX3
As long as charge pump is around 260 and holds steady, I would run it.  My 380 was the same way.  It would take 20 minutes to charge, but it held good.  If you shut the machine off warm, then restarted soon, it would take even longer to charge.  They told me if the pressure held, it was good to go.  ????
John 3:16
You Better Believe It!
so il logger
Mine holds 260 but when I shift to fwd or rev the pressure drops to nothing for a few seconds then shoots back. Also the main hose from pump to filter pulsates and jumps around. ??? I have been talking to a real nice mechanic from over near you cx3
CX3
I wouldnt run it in that condition.  You will be replacing major tranny parts.
Whos this mechanic
John 3:16
so il logger
A guy name of greg at Ozark machinery out of west plains mo. The tractor pulls like a train after warming up. But I agree on not using it. Any other ideas???
CX3
Ozark machinery is a good place.  Thats all they do is work on forestry equipment.
My old 380 would prime up to 260 then drop pressure to 0.  then do the same thing. etc.  until it finally took pressure and was fine all day every day.  It did a lot of the same things yours is doing, and when pressure came up it would work like a beast.  Its pulled at least 3 million feet for me with no problems and I sold it to a guy and hes pulled that much as well.  No problems.  But who knows it may blow tomorrow.
John 3:16
so il logger
this 450 gets to 260 psi soon as it starts. but still wont move until it warms the fluid. No mechanic that ive talked to has any explanation. CX3 in your opinion is it worth pulling the shift valve body and taking a look?
