Does anyone have any experience sawing Greenheart????
Started by joejeep, January 13, 2015, 07:44:56 PM
joejeep
Hey guys...A friend of mine has been dropping off greenheart piling cut offs to me recently. He has a neverending supply of these and doesn't mind dropping them off :).....my question, or questions are...has anyone milled this stuff. What blades would be best suited for milling it. Does it hold up well to milling thinner dimensions. Any help would be great.... I milled a few of these piles into beams with 10degree woodmizer bands..real slow..lotsa water. Seemed to work ok,,,but beat the heck out of blade.
My wife says I do everything in excess
POSTON WIDEHEAD
Maybe it comes with being an Old Goat but not sure what Green Heart is.  :)
POSTON WIDEHEAD
I read your link Brother Been. I think I'll pass on the Green Heart.  :)
First time I had heard of it.
joejeep
My buddy gets barge loads on greenheart from Guyana. His familys company builds commercial docks. Piles come in very long lengths,,some get pre cut before they drive them. The cutoffs I get are between 9 and 18 feet, dry and de-barked. Usually about twice the thickness of a telephone pole.  The stuff is ultra bug, and rot resistant. From what I have read it has such a tight grain that it can explode???? And also has a fire rating..it does burn...and it burns hot,,but takes a lot to get it lit. Also weighs more than any other wood that I have ever dealt with.
POSTON WIDEHEAD
I wouldn't mind having a few sticks of this to put in my neighbors mailbox.  ;D
joejeep
Swing on by. You can tie one to the back of your truck,,,drag it home,,, and I guarantee it will still be there when you get home :D..This stuff is rock hard.
mikeb1079
that sounds like a wonderful problem to have.   8)   i'd probably try a stellite or carbide band for these, i would imagine the price per bf would justify it?
homebuilt 16hp mill
Kasba
I have milled ecki which is very hard they use it for dock bottom blocks in dry docks for large vessels like cruises ships to rest on. I mill it with lots of water and hope for the best.
Timbery M285 25hp, Husqvarna 570 auto tune, Alaskan sawmill, Nova 1624 wood lathe, Dogo Argentino
mikeb1079
homebuilt 16hp mill
mesquite buckeye
Supposed to be really toxic stuff. I would Mask and glove up. Seems to me I remember reading stories of greenheart logs exploding on the mill. Might not be an issue with old stuff, but I would still be careful. :-\
Rachiano
Hi jojeep...greenheart from south america or ipe are the gold bars in lumber business these days.
First of all you need a mill with at least 35 phonies to saw this wood in a comfortable manner. 15hp if its an electrical mill. The best blade to cut this specie is woodmizers turbo7 blade....there in guyana is in fact where the development of this turbo7 blade started for this kind of wood. After making its success there it came back to the united states to saw other hard stuff. What you also need to add to your lube system is vegetable oil mixed with dishwashing liquid and add that to your water jug. 1 liter soap...2 liter vegetable oil...17 liters of water would be the best mixture.
Dont expect to saw too much of this a day as you will need to change blades frequently...after every 400 or 500 bf....that will also preserve blade life.
Have seen it being cut with an lt40 and soon I will be eating them too on my lt70.
Hope i helped in a way.
Rachiano
WM LT70
WM EG50
Werklust WG25 Wheel loader
DAF 2100 HIAB truck
mikeb1079
homebuilt 16hp mill
Peter Drouin
I would not want it here at my mill, Sounds like as bad as ATT poles. smiley_horserider
A&P saw Mill LLC.
License NH softwood grader.
joejeep
Thanks for all your input guys. Another load dropped off today. That brings me to about 30 or so pieces. Guess I will man up this weekend and mill a bunch of it......Sounds like I will be giving my new TK blade grinder a workout.
taylorsmissbeehaven
Hey Joe, I would be very interested to hear how it goes. I have never heard of greenheart, but have a lot of experience installing finished boards of ipe. That stuff is very heavy and  very hard. I always wondered what it was sawn with. If it works out for you it may be a small gold mine! Ipe cost a fortune around here. Brian
Opportunity is missed by most because it shows up wearing bib overalls and looks like work.
joejeep
Milled up a few of the greenheart piles yesterday. Used the new 4degree bands recommended by woodmizer. This stuff eats blades up. I am using lube and cutting ULTRA slow. I went through a band every log. Then the blade would start to wander. Kind of heartbreaking because I have so much of it, and its not much to look at :-\...Guess I will mill what I have and make decking with it.
mesquite buckeye
I've used both the 4° and 7° blades on mesquite, another notorious blade eater. I find the 7° cuts faster and longer than the 4. No Idea why.
Hopefully your saw has the debarker, which is a huge help on blade life. Also don't be stingy with the lube, especially on dry wood.
Greenheart is suppose to rot like never, so could be a good one for decks or other projects requiring rot resistant wood.
I wouldn't give up yet....
joejeep
Thanks for the advice and words of encouragement.. This wood really puts my patience to the test. I have the track speed at a crawl,,,and the minute I cant stand it anymore, and turn speed up a bit, the blade dives in the cut. I am going to saw what I've got, but don't plan on taking any more.  :-\   Does anyone want a good deal on a load of nasty wood that will last forever? Its a shame because the logs come to me debarked and perfectly round. Beautiful stuff until you try to cut it.
mesquite buckeye
Also have plenty of tension on the blade. that helps.
mikeb1079
if you have a reliable supply of free greenheart logs you gotta figure something out.  from what i can see it's a very high dollar wood.  snoop around maybe there's a swing blade mill in your area that you could test out.  if it performs better maybe that's the route to go.  if you can mill and find a market i could see making some nice $
homebuilt 16hp mill
joejeep
MikeB, Thanks for the great advice. Never even thought about that. There is a guy real close with a swing mill. I think I will drop by one day and drop him a log. He may jus have better luck. My buddy just called to say his dockbuilder has another 100 greenheart cutoffs coming. Its killing me not to be able to process these. :-\
mikeb1079
yeah i hear ya...that would bother me too.  especially such a premium timber.  i don't have any first hand experience with swing mills but have heard that for whatever reason they stand up better to the extreme tropical hardwoods.  i think it's definitely worth a shot, this is a unique situation for sure....let us know how it works out.   :)
homebuilt 16hp mill
Jemclimber
Is it worth buying a carbide tipped blade to find out the results? Just a thought I don't have any experience or knowledge with a carbide tipped band saw blade.
lt15
joejeep
It may be worth buying carbide or stellite,,,if I had a buyer for this wood. Don't yet though.. The price for these blades was around $76 each. And I don't believe I can sharpen with regular stone wheel.
