LOGRITE 78" Megahook
Started by RayMO, January 09, 2015, 10:32:40 PM
RayMO
How many of you all have or have used one . Just ordered one direct from our sponsor and figured the $200.00 plus price might be a bargain if it saves my abused back. I haul logs to a couple of Amish mills that have no unloading equipment . Thinking it might make hand rolling some of those big logs off the trailer a bit easier and safer .
May have to fashion a means of chaining it with lock to back of truck to stop the thieves though .....
Father & Son Logging and sawing operation .
WV Sawmiller
Raymo,
   I'm anxious to see what info you get. I just got my mill 2 days ago and cut a big tulip poplar and have logs 16' long and 24" diameter and they are a bear to move. I'm still learning about how much and what kind of equipment I still need. Good luck with it. Sounds like a fine tool
Dan_Shade
I have two of them.  they are handy.  I recommend two, if the logs are that big,  you'll want help.
also, a hi-lift jack is useful for moving big logs.
lots of dull bands and chains
backwoods sawyer
I agree they work best in pairs ;)
I picked up a pair of the heavy 60"  and have used them hard for several years and they have held up well. They work well on logs up to 36".
I still need to get a pair of the 78" megahooks for those over sized logs.
Saves on the back and gives you good control of the log.
Backwoods Custom Milling Inc.
terrifictimbersllc
I have one, pretty simple, when a longer lever & big hook will help, & handing it to the customer, makes it easier on me. I pretend its more important that I'm at the mill controls. :) :)  Could use 2 but usually if it gets to that I get out the strap, chain and hook that I rig up to the sawmill clamp to pull big logs toward the mill.  I also carry a hi-lift extreme jack, sometimes two but these don't often get used to move logs for bandsawing.
You can wrap a chain around the stem where the hook attaches and padlock it tight there if you want.
FarmingSawyer
I guess it's time to pony up and get a Logrite.....I was working in the woods Thursday and my winch cable shifted, the log rolled and somehow the cable got on the wrong side of the tree my peavy was leaning on..... When the cable came tight it sheared my wooden handle. I've moved a lot of big wood with that ash handle. Guess it was done though......
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
If ordering one,order some Blue Creeper too.   ;D
I find it indispensable for turning the big logs on a manual mill.  It will save your back for sure, and will let you turn logs that you could not turn with a 60" cant hook.
RayMO
Sounds great! I have the 60" peavy and love it but needing a bigger hook on a few logs and easier is better in my book .
Andries
The MegaHook really is mega. A size comparison:
Over the years we ended up with one of each colour.
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
Quote from: WDH on January 10, 2015, 07:56:45 AM
Worth every penny buck.
LT40G25
Ford 545D loader
Stihl chainsaws
Peter Drouin
Quote from: Andries on January 10, 2015, 01:01:00 PM
How long is that Mill?
A&P saw Mill LLC.
License NH softwood grader.
Andries
I can mill up to fifty two feet.
LT40G25
Ford 545D loader
Stihl chainsaws
Andries
For the sawyers with manual mills and heavy logs here's something that works for me.
I have an ongoing milling job that requires a large cedar logs to be halved, right down the centre.
That requires small tweaks and turns plus levelling off with the manual toe-boards.
Logrite sells parts for their tools, the MegaHook 'hook' part only can be used to turn any massive log.
Add a length of chain to the hook with a grab hook at the other end. Use forks on a loader, or, if no loader, use a HighLift jack to roll the log on the bed. Remember: set all this up so that the log rolls in the direction of the log supports>
LT40G25
Ford 545D loader
Stihl chainsaws
gfadvm
I have 2 of the shorter Logrites and love them but really need longer ones. They are outside my budget for now so does anyone have any ideas about lengthening/using a cheater bar on the ones I have? Pipe is just too heavy.
From the peanut gallery......
If they were designed for a cheater bar then 1) they would be heavier material in the short handles and 2) they would have to be more expensive to buy.
Hope that answers the question... as I read it. ;)
RayMO
The shorter ones will only work well on smaller dia. logs compared to the bigger/longer hooks so a cheater pipe might be ok as long as you don't exceed the hook limits and just need more leverage to make it less strain-full on your back.
Not all of us are 6 ft plus and over 200 lbs and some are more senior than others and need a little more help lifting now and then .
Peter Drouin
A&P saw Mill LLC.
Ga Mtn Man
The Megahook is on my list of things to get when I have the $.
I'm curious, how do you go about aligning a 50' mill to ensure that it is dead straight?  ???
terrifictimbersllc
By eye, but with binoculars. :D
Andries
I asked Jake (CustomSawyer).
Turns out, he's got really good binoculars.
LT40G25
Ford 545D loader
Stihl chainsaws
dboyt
Dan, that log would roll a lot easier if you'd pull the chock.  Just sayin'...  That hook for turning the log with a front end loader works great.  It is also a good way to safely roll logs off a trailer.  Just hook up a tractor (or horse) and roll it right off.  Is the hook geometry different with the megahook so that it will handle larger diameter logs?  Interchangable hooks would be a good idea.
Andries
The MegaHook geometry is the best.
I've used plenty of cheapo and bush crafted peaveys and the Logrite hooks just grab and hold on. Big or small.
Not sure what the formula is - maybe Tamiam could answer that.
dboyt:
The megahook - hook and chain combo works on any of the logs that we've worked with. Not sure I'd take the time and trouble to swap out for a smaller hook if the big hook is doing the job.
Sometimes it's just "pitter patter, lets get 'atter". . . and then . . . there's days like today at -41 degrees.
Good time to be on the FF!
LT40G25
Ford 545D loader
Stihl chainsaws
Tam-i-am
the hook geometry is key to making the hook grab.  Trade secret so can't say more about that. :D
RH003 (replacement hook for Megahook) optimum range is 15"-45"diameter log
RH002 (replacement hook for any of our 60" handles) optimum range is 10"-36" diameter log
RH001 (replacement hook for all other tools) optimum range is 8"-32" diameter log
Quote from: gfadvm on January 10, 2015, 08:39:31 PM
Quote from: RayMO on January 10, 2015, 10:17:57 PM
RayMO and gfadvw - using a cheater bar can cause you to exceed the limit of the handle and cause the handle to bend.  A cheater bar voids your warranty.
I'm not sure what size handle you have as you only said smaller but we have three different strength handles.  The short mill specials being the lightest and the Xtreme duty tools which includes the Megahook being the strongest.
Get Stuff Moving Today!  www.bluecreeper.com  www.facebook.com/Bluecreeper
Tamiam, I probably asked before but have you ever tried putting a light spring to push the hook to the point. You could one hand push the tool into the log and  kinda use it like a ratchet to get another bite. Frank C.
