board deduster
Started by Joey Grimes, November 29, 2015, 08:59:42 PM
Joey Grimes
We have a issue with getting wet sawdust of freshly sawn green boards we have tried compressed air but the only thing that seems to work is a wire brush . Has anyone made a homemade deduster.
94 woodmizer lt40 HD kabota 5200 ford 4000 94 international 4700 flatbed and lots of woodworking tools.
Joe Hillmann
I use this
http://www.sand-rite.com/b-12.html
You can use it with just the brushes and no sand sandpaper if you want.  It is only about 4 or 5 inches wide.  It does a good job of removing the sawdust.
Joey Grimes
Thanks mm I'll try the sheet rock knife.
mesquite buckeye
A garden hoe works too. better if you get a really fat one.
Or just a chunk of square edged lumber cleans things decently. We just use shorts laying around the mill. ;D
YellowHammer
We also use a sheet rock knife, 12 inch wide.  One fast swipe and the board is clean.
A while ago I was experimenting with using the brush part of a 2 foot push broom, and mounted it bristle side up, maybe a half inch proud, on the underside of my drag back table.  As the board would be returned by the dragback, it would pass over the bristles of the brush, and would be swept clean.  It worked pretty well, I used it for quite some time.
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
Kbeitz
Quote from: mesquite buckeye on November 29, 2015, 09:45:54 PM
I woild not be telling everyone that you got shorts laying around the mill....
Love machine shop work
and Wood work shop work
And now a saw mill work
longtime lurker
anyone tried spray suppressant skirting... the broom like strips used on truck mudguards? mount them top and bottom on the line so the boards pass through them coming off the saw. Might work.
terrifictimbersllc
10 or 12" drywall knife, economy one with a somewhat flexible blade, mine is bluish, fashion a 3' handle on it is better on the back and faster.  But first give the board a couple good bumps on the mill bed.
