Saw blades / board feet
Started by RoundMountainLogger, December 29, 2014, 07:34:27 PM
RoundMountainLogger
How often to change a band sawmill blade ?
And where to get sharpened in Maine?
Tractor and farmi winching
POSTON WIDEHEAD
What brand of mill do you have? Welcome to the Forum!
The bottom line is, you change them when they get dull.
There are a lot of variables that determines how long a sharp blade last.
What degree blade am I using for a particular species.
How clean is your log....to be determined by de-barker or hand cleaning.
Speed of your cut.
Metal in logs.
Care of your blades.
Just a lot of variables and others will add to this list.
Banjo picker
Welcome.  That will depend on several things, one being do you have a debarker. Banjo
RoundMountainLogger
It's my buddies sawmill made by quality mfg inc from New York I think.
I AM the debarker...
Downeast Logger, your mileage may vary but two bands a day is close unless you get into a lot of mud and hardware. You will need to ask local guys who sharpens in your area. Frank C.
Dewey
Where in Maine are you.... There is a outfit in Howland...  I believe Thomas Mills in Brooks does also..
Chuck White
Welcome to the Forestry Forum, RoundMountainLogger.
I usually get anywhere from 700-1,000 bf per band, and I have a debarker, so I will normally use 2 bands per day unless I hit something in the log, like nails, wire, stones, etc.
I sharpen my own bands!
YellowHammer
I normally change my band at lunchtime, as I generally always get a half day out of them, but never a whole day, so change it whether it's sawing bad or not.  If it's not dull by then, it will be shortly. Of course, if I throw a spark from hitting grit or start sawing waves, it comes off pretty fast.  Of all the things related to sawmilling, logging, kiln drying, planing, and selling wood, just about the easiest thing in the whole process is putting on a sharp blade. 8). Despite that, there is always a tendency to want to run a band too long.
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
losttheplot
I sometimes get two logs out of a band.
Unless they are particularly dirty, knotty, old, big......
Then its sometimes two bands per log.
Five or six bands per day.
Using a log arch instead of skidding helps me lot.
20hp manual mill.
I find it easier to sharpen a band rather than try fighting with the bark, unless its spring time or the log has been sitting a year or so.
DON'T BELIEVE EVERYTHING YOU THINK !
