my first glue up table
Started by yukon cornelius, December 24, 2014, 08:11:15 PM
yukon cornelius
A guy ask me to make a table for a feed store opening soon. I said I could do it but I wasn't sure of what I had gotten into. I have no thickness planer, jointer, or enough clamps to do the job. I had never built a table like this nor had I seen one built. I dove into it and here is what I ended up with. I am pretty pleased with it! the owner seems to be but he has only see the pictures.
It seems I am a coarse thread bolt in a world of fine threaded nuts!
Making a living with a manual mill can be done!
Den-Den
The table looks great.  You did a good job on it, a thickness planer would be nice if you plan to make many of them.
I too have only seen a picture and I see why he seems pleased.   8)
Swatson
I like it very much.  Did you use a tenon tool or a lathe?  Either way it looks very nice.
I cant figure out which one I like better: working with wood or making the tools to work with wood.
yukon cornelius
I use tennon cutter. lumberjack brand.  Thanks guys!
Delawhere Jack
You did a real nice job gluing up the top. With a couple good hand planes and careful glue up, you can make an awful lot of nice pieces without the need for a surface planer.
You can never have too many clamps.  ;)
POSTON WIDEHEAD
Stuff like this makes my mouth water! This is really nice.  :)
mesquite buckeye
yukon cornelius
 I used 6 clamps but I think 8 would have been better. I had to borrow ( a very rare thing for me) 3 clamps from a neighbor. to plane it I used my bosch electric 3.5 inch and then belt sanded. and then sanded it down to 320. I think I could have sanded more as when I oiled the top I did find a few belt sander marks left. not to bad though. I left it with a teak oil finish. any thoughts on the oil? I read several opinions on finishes but always end up oiling. I need foolproof ideas as finish is new to me. rub on polys?
A real nice natural looking finish is 100% pure tung oil mixed 50:50 with clear mineral spirits.  Read about it here:
http://www.realmilkpaint.com/oil.html?gclid=CMa5ioOY4cICFQ9gMgodi2UAUw
LaneC
I am like MM. I can see why he is pleased. That is very nice. What kind of glue did you use? Again, very nice.
Man makes plans and God smiles
yukon cornelius
I used gorilla glue. that's what my neighbor uses. I bought tightbond 2 to use but he swore by gorilla and since I already had some it was worth a shot. I think it worked well. i have 2 braces underneath that the legs are tennoned into.
I have always been to timid to do a glue up in fear it would fall apart. do I worry about moisture content in the future? this slab was cut in july and kept in the shop. moisture was around 12%
Larry
Nice looking table and chair set.  Maybe the feed store owner will let you put a little sign close to the table.  Custom made by Yukon.
ERC is oily, so I try to wipe the joint right before glue up with acetone.  I forget half the time will no ill effects noticed.
I'm a big fan of Waterlox products.  Last month Fine Woodworking tested a dozen similar finishes that can either be brushed or wiped on.  Min-Wax Fast Dry Poly was rated best tied with another General finish.  As a bonus it was the cheapest and widely available.  I'm going to try it out soon....half the price of Waterlox.
On your sanding try stopping at 180 and see how a sample piece looks after finishing.  Sometimes I don't go past 150.
Merry Christmas!
samandothers
fishpharmer
Lucas 618 with 50" slabber
Deere 5065E mfwd w/553 loader
clww
Very nice work that looks great! :)
Many Stihl Saws-16"-60"
18-Wheeler Driver
jamesamd
Nice work, now Your hooked  ;)
Jim
All that is gold does not glitter,not all those that wander are lost.....
drobertson
Looks good to me!  Pictures more often than not don't do justice.  Handmade brings the project to another level in my opinion.. pretty sure this won't be your last,
hackberry jake
I usually stop around 150 grit or 220 grit. I use poly almost exclusively though and it builds a protective layer on the top of the sanding job. If I were to use an oil finish, I would sand it down further. I can't believe you don't have a thickness planer. After seeing some of the projects you have built without a planer, you are a true craftsman.
yukon cornelius
Quote from: hackberry jake on January 07, 2015, 08:25:49 PM
I just added poly to my finishes this week. I have used a lot of it already. I am using minwax poly. I brushed it on let it soak in and then wipe off any excess and polish with a rag.Then let it dry. if you go to my facebook page I have a lot of other projects I haven't posted here. i really like the finish it leaves. it seems to really fill the pores of the wood better. im not sure about its outdoor life though. how do you think it holds up outdoors?
I don't consider myself a craftsman but a very green beginner. I just build a lot of things since this is our only source of income. I hope to be able to afford a thickness planer this year along a jointer and lots of clamps oh yeah and a big bandsaw, a router table or an extra router to mount on my table saw, a good table saw and a dust collector. oh and more concrete for my shop floor, more tennon cutter sizes, some tools for my lathe and ....and.... ;D I have big plans for this year! one step at a time.
No, the poly will not hold up outside.
yukon cornelius
Thanks wdh! that's what I thought. I think I will leave teak oil as my outdoor cedar finish but I am switching all my indoor finish to poly
mmartone
Looks fantastic, thanks for sharing a cool project!
Remember, I only know what you guys teach me. Lt40 Manual 22hp KAwaSaki, Husky3120 60", 56" Panther CSM, 372xp, 345xp, Stihl 041, 031, blue homelite, poulans, 340
yukon cornelius
well I have to re visit this. all tennoned joints are loose. i am thinking wood shrinkage is a major key factor. the table is set up near a pellet stove and is pretty hot. the wood legs have cracked like i have never seen before. my plan to fix this is 1: adding an extra set of braces on the chairs just below the seat boards. 2: cut a slice through the tennon and insert a wedge so as the tennon is pushed into the mortise, the wedge will spread the tennon nice and tight in the hole. ( i did it once before on a bench just to try it. worked great!) 3: a larger washer head screw to hold the tennon in place securely and glue it again
this set is in a store so it has to be extra sturdy. i had never made chairs like these before and the customer knew it. He is a nice guy and  wasn't upset thankfully. im a bit embarrassed but i will do what it takes to get it right.
rasman57
I bet you are right about that stove.  That and the public setting would be hard on the assembly for sure.  Good for you...making it better.   That is integrity and good service!
