Hydraulic valve worth repairing/ Garrett 20
Started by tantoy, December 24, 2014, 12:07:18 PM
tantoy
So the spool valve for the blade cylinders is seeping oil around the spool nearest the control handle. I have not even been cycling the valve because I don't have my new cylinders hooked up yet. Is it possible to put new seals in it. Is it just o rings? It looks like I could buy a new valve for around 100.00. Thought I would ask before just buying new.
Also any guess as to how many GPM a system like this would be? I was thinking about 10?
Thanks and Merry Christmas, Fred
Picture of the pump
1968 Garrett 20 Skidder
1991 Ford 1920 Tractor/Loader
2000 Takeuchi tb135 Excavator
Stihl 020, 041 Super, 084
Husqvarna 61, 181SE, 357XP
1270d
i would think there is just an o ring or two in the spool bore.
Autocar
I agree just two O rings on each end of the spool cheap fix to try , but also had to replace because of ware on the spool there are company's that re chrome spools. Good luck Bill
Bill
tantoy
Thanks guys, I pulled the valve off the machine. I will pull it apart and see in new o rings will fix if the spool looks ok.
North River Energy
Is that a Gresen?
If so, most likely has a four-lobed square section seal rather than standard o-ring.
My local hydraulic shop had them for a fraction the prices I found online.
tantoy
Quote from: North River Energy on December 24, 2014, 10:32:54 PM
Is that a Gresen?
Yes, thanks NRE, It is a gresen. Thanks for the input about the square o-ring.
North River Energy
^You betcha.  What's the spool diameter?
I can check that dimension against the seals for my Bobcat M600.
tantoy
Quote from: North River Energy on December 25, 2014, 09:03:44 AM
So the spool diameter is 1". Here is a picture of the seal. There is one at each end of the spool.
tantoy
North River Energy
Looks like a lip seal.  I was thinking quad ring.
If it measures 1" x 1.25"x.135-40", and you can't find the exact match, p# 6 515 313 from Bobcat might work.
Keep up the good work on the Garrett.
tantoy
Quote from: North River Energy on December 25, 2014, 04:57:21 PM
Thanks much sir, :)
pineywoods
Looks exactly like the seals in the hydraulic band tensioner on a wm lt40. The sizes look the same.
coxy
I have lots of them single spool valves off our old pickers for the out riggers but you are a little to far of a drive  :D cant wait to see it all shinny yellow :laugh:
mad murdock
Air Oil Products, AOP has tons of selection of o rings, quad rings, chevron seals, etc, etc. they have an office/warehouse in the Seattle metro area.  Another good source is Spencer Fluid Power in Kent.
tantoy
Thanks Mad, Spencer isn't to bad a drive and I need seals for my steering cylinder also.
tantoy
NRE,
That measurement is the same as mine. Just curious what Bobcat machine and valve that is? Thanks again!
North River Energy
70's era M600.
All three spools in the valve bank use that seal.  (boom lift, bucket tilt, auxiliary).
Or at least that's what the dealer sold me...
They came in a pack of 5, and as I recall, were not expensive.
The Gresen bank on my old Prentice uses the same type of seal, although those are larger.
