Whatcha Sawin' ???
Started by Magicman, December 23, 2014, 12:00:38 PM
Farm29
New to saw milling but have been reading this forum a lot lately thanks for the good info I have sawed a total of 187 bf of 4/4 ERC but hope to saw more soon.  Just starting out so I have a lot of learning to do.  Have a good pile of cedar logs just lacking in time to get to them.  Thanks again for the info. I can't figure out out to put pics on but if I figure it out I will
96 lt40 Hyd 24 hp onan
460 rancher
WV Sawmiller
F29,
  Welcome on board. Good to hear from you.
   I towed the mill and spent the day cutting walnut at a good friends house. He had several large trees cut in his yard, a guy took a couple loads to the mill and left a bunch cut in short, often firewood, lengths.
Down in the ditches, short, scrappy pieces.
I set up in his drive, had to dig in front landing gear and jack up the rear and still sloped down hill a little.
Cut several of these crotches. Nice figured wood but hard to load and clamp. I'd center on one arm and buddy ran the hydraulics while I held in place.
Won't win any beauty contests.
More sapwood than I'd prefer but some pretty pieces.
More ugly pieces.
Max out my cutting width.
More pretty pieces. Note the green tint typical of fresh cut green walnut.
Cookie dough?
Maxed out blade width, pulled blade off on one. Final result 3-2"X23" "donuts"
Farm29, Scroll to the very last topic on the index page for picture posting instructions, and Welcome.
ncsawyer
WV,
I went and looked at a walnut job on Sunday after church and many of the logs looked like the small ones in your picture.  He said he had some 28 inch logs that were 16ft long, but his granddad traded them to the guy who did some clearing for him.  At any rate I should be able to get some pretty nice stuff out of what the excavator guy left.
2015 Wood-Mizer LT40DD35
Woodmaster 718 planer
Ford 445 Skip Loader
ncsawyer
I had the day off today (President's Day), so I took the opportunity head down to my father-in-law's farm and take care of some of the trees that were taken down during the hurricane back in October.
When I got there, there was a HUGE pile of tree length "logs"  Mostly red oak and pine with a few white oaks and hickories.
We cut one hickory, a bunch of pine and red oak and a few white oaks, the rest were firewood quality.  He had a guy running the tractor, chain saw, and pressure washer.  He was sorting the firewood out from the saw logs and cutting them to length and then pressure washing all the mud and gravel off of them.
There were also two off bearers as well, so I didn't have to do a whole lot except run the saw.
We had a pretty good day and put in 10 solid hours on the mill.  We ended up cutting the whole pile except 9 logs.
I didn't tally up the board feet since it was scattered all over the place and since it was for my father-in-law he got the "family discount".  I always jokingly tell him that the family rate is twice my normal rate.   ;D   He always requests the normal rate!  ;D
WV Sawmiller
NC,
   Good luck on your Walnut job. Some of the odd, ugly pieces yield some real pretty wood.
Farm29
Thanks MM for the photo help I hope it worked this is one pile of cedars I have to saw.  I took the the stack I had already cut to a hardwood lumber yard today to see if they were interested in it. They said it looked good and would buy more of it and that I could saw it 8/4 which is better for me.  Looking forward to getting more sawed to take to them and that there is a market for it
460 rancher
That is very good looking ERC, and congrats on the pictures.
What part of Missouri?  You might be interested in attending this get together:  Chilly Chili
Farm29
I'm between Jefferson City and Columbia off hwy 63. The cedars are out of the Missouri River bottom hills.  When I took the stack in to sell yesterday they asked what I did with all the sap wood I guess they thought I was cutting the hearts out. I showed them that pic and they understood.  It took me a while to cut the first batch because of mill problems. I was fortunate enough to find a guy that had a 1990 lt40 hd that had been setting for 5-6 years he said if I got it running I could saw with it for a while so I'm getting a first hand try at it before I have to front the cost of a mill... But it had 4500 hrs and a lot of slop in the head fuel lines bad electrical issues and other things.  I broke 3 blades cut bad crooked cants and other issues getting started.  But after 5-6 hrs off adjustments ??? And a new box of 10 blades I'm ready to get at it again ur alls info on her as been a big help thanks again
460 rancher
gww
Farm
Where you are puts you about 60 miles or so away from me.  Sounds like the guy with the mill you are using is coming out pretty good if you are working the bugs out of it for him.  I find what you are doing to be interesting and I hope it works out for you.  If you ask me, cedar is a good wood to use to work out the bugs with cause I find it about the easiest of the things I cut.  So Out of those ten blades you have, the cedar will use fewer of them and then when you get it right, the hard woods will be able to give you the most blade for what you are cutting.. I can cut a lot of cedar on one blade compared to how much hard wood I can cut.
Good luck
gww
Farm29
Yea so far he's getting a good deal but I hope to saw a good bit with it to sweeten my side of the deal a little.   Yea I picked cedar to learn on because there is a good bit of it around and I can get it at a ok price if I cut it down the stuff I have know cost a little more but it was cut and delivered to me so I don't have as much sweat in it.  I have my eye on a 96 lt40 hd I would like but want to make sure i can make a little jingle with it before I buy it.  Not sure if cedar is the best pay out but it's fun to cut and makes me smell a bit better when I get home after a long day 😎
460 rancher
paul case
pc
These are on tap for me tomorrow.
Three ERC logs two of which are in the 16" class.  Hopefully they will be as good as they look.
When it is good, it is real good.  When it is bad, it is real bad.
Yup, that is why I am anxious for the customer at least.  I get paid the same regardless of what they look like inside.
Briankinley2004
Farm29
Got to saw a little bit but worked on a ruff log deck and got some cedars bucked to length and put on it. Should be nice when I do get to saw again.  Had another bug to work out on the mill for some reason what ever keeps the outer blade guide frome coming in to far didn't work.  It fell out of it rollers and did a number on a very new blade 🤔
460 rancher
caveman
I wish I had a truckload of cedar like that MagicMan.
Caveman
Actually it was a nice load of ERC that began this thread a little over two years ago.   ;D
fishfighter
I too would love to a load of them. ;D
No sawing for a few days. Got to go catch some crawfish to bait some trotlines. In need of some fish for lent. ;D The wife flat out told me to go fishing or she will be buying fish. :o Got a nephew that will be fishing along side me in his boat to keep a eye on me. :D
gww
Fish
QuoteGot a nephew that will be fishing along side me in his boat to keep a eye on me
Is it a boat that you made?
Cheers
gww
ERC, not really enough to make it worthwhile, but my business is to satisfy my (repeat) customers.
We went for maximum yield from the logs.
All sawed 5/4 with the widest being 12".  It didn't take but one hour.
fishfighter
Quote from: gww on February 23, 2017, 09:37:46 AM
Fish
Cheers
gww
No, a back water flat bottom alum boat. To many stumps and logs that I have to jump. I will be hunting some cypress logs to. ;D
Tomorrow's sawing will be another ~60 mile road trip.  I have no idea how large or what it will be, it will just be a surprise.  :o  No matter, I will take is as it comes.   :)
I talked with the customer and all of the lumber will be kiln dried, planed, T&G, and used for wall paneling.
He named off Red Oak, White Oak, Sycamore, Hickory, & Cypress.   headscratch
