Techniques for New Sawyers
Started by Privacyleech, December 13, 2014, 09:43:10 PM
Privacyleech
So after purchasing my gently used Woodmizer LT28 last weekend I finally got to cut a few decent logs on it today. They were some pine logs about 12'6" long and 18"-20" diameter. I just plain sawed them into 2x12's and 2x10's as we were fighting the daylight.
These were unloaded in a guys yard from a tree job a few weeks ago. He said I could have the lumber if I would come cut them up and get rid of them. This was a perfect opportunity for me to get a little experience on the mill as opposed to my milling experience via Youtube and The Forestry Forum  :P
We were a little slow getting going but once we got the mill leveled and loaded we were making sawdust in no time.
I was thinking of turning this post into a small gathering of information for techniques and methods for those of us who are just getting into milling or are pursuing it in the near future. I know there is a lot of information on this forum, but maybe you guys wouldn't mind sharing some of the "tricks of the trade" and digging up some of the links to older but informative posts that come to mind.
What trick do you use to roll a log up the ramps and over the jack stand that is in the way?
Or do you just slide the log down to miss it?
Privacyleech
Quote from: beenthere on December 13, 2014, 09:45:43 PM
My favorite trick. . . Luck! It lined up just right where it rolled right next to the jack stand. I think we pushed the log farther up the mill as we took some weight off of it and that let me get the mill head down to where we could finish sawing it up.
Ocklawahaboy
I don't see a logrite in your pics.  If you don't have one, Order one. Looks like you have a good start.  I use thinner leveling material.  Those outriggers start to get in the way of the blade when the can't gets thin and you want those last few boards.
Privacyleech
Quote from: Ocklawahaboy on December 13, 2014, 09:53:04 PM
The gentleman I bought the mill from threw in his logrite it just happens to be camera shy. . . Funny thing is that I started trying to roll the logs by hand before I remembered that I had it in the truck bed! DOH!
Good idea on the outriggers. The engineer in me takes over sometimes and says 4x4 stronger than 2x4 but like today i quickly found out that the outriggers sure do get in the way as you mentioned. Do you think 1x4s are too thin for this application?
Thanks for the suggestions
The tops of the outriggers need to always be below the sawmill bed rails, even if you sometimes have to dig them in.
It keeps "bad" things from happening.  Put the plug back in the hole when you finish sawing.   ;D
reswire
Keep an eye on those log stops too!  They seem to inch up when you least expect. ::) ::)
Norwood LM 30, JD 5205, some Stihl saws, 15 goats, 10 chickens, 1 Chessie and a 2 Weiner dogs...
Privacyleech
Quote from: Magicman on December 13, 2014, 10:24:38 PM
These are the tricks I was talking about. I didn't even consider going below grade. . . I just thought "Hey I have a few extra feet at the other end of the mill so Ill grunt and strain and get the log over there so I wont cut into the outriggers..."
Thanks for the tip!
Delawhere Jack
Put your outriggers right on the ground. It looks plenty solid. I usually only put blocks under the feet if I'm working on a paved surface, to protect  the paving. Easiest if you keep the mill head to one end of the mill, and jack up the other end, then move the head to the other end, and jack the opposite end.
If you leave the outriggers stickup up above the bed, you will eventually try to saw one.......
Know where your backstops and clamps are in relation to your vertical scale. Get in the habit of sighting down both sides of the log to insure that you don't hit them.
Mostly, spend some time searching and reading the FF. Search for and read up on terms such as taper, leveling pith, sway, curve, hump and horns, etc. A few hours spent reading here each week will quickly get knowledge that would take years to learn on your own.
Welcome to the forum, nice mill you've got there!
Delawhere Jack
Close the doors and windows on your truck if the wind is blowing from the mill towards the truck!  ;) There are few things more annoying than cruising down the road and having sawdust blowing around inside the cab of the truck.
Ocklawahaboy
Quote from: Delawhere Jack on December 13, 2014, 10:53:53 PM
Also, Keep in mind where the sawdust is blowing vis-a-vis your neighbors.  Like me, your running a mill very close to them and you don't need to give them a reason to get upset about it.
Chuck White
You might try searching here on the Forestry Forum for "Sawmill Gremlins".
There are lots of them out there and they will show up when you least expect it, like when you have a bunch of people watching you run the mill!
slider
Always take a shovel when you go portable.
al glenn
shinnlinger
I saw a post somewhere were somebody hung a 5 gallon bucket on his sawdust chute to catch most of the dust.   Just gotta empty it once in a while but could be a good way to try to contain the mess.
Don't split the pith or try to box your heart.
Good on you for getting you blade in the wood.   Wood happens so don't get too worried about getting it right all the time.
Shinnlinger
Sixacresand
Quote from: slider on December 14, 2014, 09:19:06 AM
Sometimes there is not a bathroom available.
YellowHammer
Always set your clamp lower than your backstops, or you will eventually forget where it is and saw into it.  The backstops are on the visible side, the clamp is on the hidden side.  So if you clear the backstops, you will clear the clamp.  Also, go ahead and buy a small can of Kubota Orange and another can of black spray paint.  That way when you saw into our mill, you can quickly cover it up before somebody notices.  :D. Of course if somebody is there when you saw into your mill, they will know pretty fast!
YH
YellowHammerisms:
Take steps to save steps.
Be smarter than the sawdust
goose63
The bucket helps a lot bought 95%less saw dust on the ground
  its easer to dump the bucket on the tractor than shouvle the dust off the ground
goose
thank you to all the vets
Dave Shepard
I had a bucket on my mill for a couple of cuts, but it fills up too fast. Maybe two passes, if you are lucky.
http://youtu.be/tySbzAfTzdo
Chuck White
Privacyleech, you might want to do one of the first things I did back when I first got my mill.
1. Know how low your blade can go before hitting the log stops (uprights).
    My blade will clear when it is 11¼" or higher.
2.  Know how low your blade can go before hitting the clamp.
     My blade will clear when it is 5½" or higher.
3.  Make sure that the tops of your outriggers are below the bed.
Knute
Set your mill up so the prevailing winds are at your back when sawing. Keeps much of the sawdust out of your face.
Foxtrapper
Wood-Mizer's log scale will tell you when you need to check the stops or the clamp.  It has a different color to it when you get to 12", and red when you get to 1".  Just have to pay attention to it.  Also, don't know if your mill has the log deck package, but it sure does make the job of loading and turning easier..
2014 WoodMizer LT28
goose63
Dave I can make 4 passes if I shake the bucket real good on the third still beats that ol scoop shovel
goose
Dave Shepard
I guess it depends on the size of the logs. I was experimenting with the idea of making a box with a dump on the bottom so I could open it over a vacuum port. The problem was that on a long and wide cut, like a 40' timber, I was going to have to dump at least twice per cut, or have a huge box to catch it in. Wasn't going to be practical. Now, I just blow it all in a windrow and bulldoze it out of the way with the tractor.
Piston
On the other end of the "sawdust containment" tip, is the idea of leaving the sawdust right where it lies.  If you mill in winter with snow on the ground, or your milling on a concrete pad or paved surface, let the sawdust build up, then spread it out a bit to make a walking "path" along the mill.  Keep widening it out until it's a good few few wide and the length of the mill.  A good bedding of sawdust will keep your feet warmer than just walking on the snow will, it also helps with traction after packing down the snow.  Likewise, it helps out on a hard surface by giving you a nice soft surface to walk on, and your feet will appreciate that after even a couple hours of milling.
JimRogers gave me this tip and I've used it many times.  Of course, it may not take long before you HAVE to move some sawdust, but leave a good bed to walk on.
Here is a thread that you may find interesting.... JimRogers was kind enough to offer to come over to my house and show me and a friend some really great tips and tricks and a general class on "introduction to milling" when I was brand new in 2009.  I documented a lot of that here.  He also shows some good pics of the bucket idea as well how to cut and store/dry stickers and I believe he goes over making pallets and lumber handling as well.  I haven't read that thread in a while so I'm sure there is more than I can remember.
https://forestryforum.com/board/index.php/topic,40309.0/all.html
-Matt
"What the Lion is to the Cat the Mastiff is to the Dog, the noblest of the family; he stands alone, and all others sink before him. His courage does not exceed his temper and generosity, and in attachment he equals the kindest of his race."
