Lifting logs - winch issue
Started by Gideon_70, December 07, 2014, 10:05:28 PM
Gideon_70
Hi Everyone!
Last weekend I was loading some logs with my arch, and my winch broke.  I had a trailer style hand winch on it, and it worked pretty good lifting, even though it was sometimes hard with larger logs.  But it gave up the gears and is now a boat anchor.
I tried to replace it with a come-a-long thinking that it would be faster, but even though it was rated at 8,000 lbs, when I got to a log that was in the 1300 range, trying to lift it was.... herniatingly difficult.  So I went back to a hand cranked winch, and it again, worked pretty good, but scares me a little.
I wanted to upgrade to a stepped down winch with a higher capacity, but the ones I've seen were not really made for dead lifting, but pulling. The largest I could find was about 2500 lbs pulling limit and I think 1200 lifting.  Under capacity = sudden death.  I like breathing.
I looked at power winches, but they had the same problem, plus I need to have battery power at the job site.
I have a claw on my home log arch but all I do with it is lift and walk the log to the mill.  The bigger arch is attached to my Cub Cadet and I pick up in people's yards and pull to the road.  I lift the log about 3' up, and then back the arch to the trailer and lower the log... so I need to be able to lift.
Any ideas?
You cannot reduce crime by disarming the victims!
I used this one:  Winch  I also still use a block which halves the load on the winch.
kelLOGg
I like chain hoists for lifting and use one on my tractor arch. Mine lifts high enough to get the logs off the ground and is easier to operate than a come-along. It takes some fabrication to mount it high enough to lift.
Bob
FarmingSawyer
I got a SuperWinch TigerShark 9500 on sale at Home Depot. Very impressed with it. It slow as moles asses but it does the job. But you have to have a block to halve the load or the battery doesn't last very long.  I made mine up so it can fit on the mill, or the truck. When I get a trailer I'll make the receiver hitch work on that too.
The only thing I don't really like about it--apart, perhaps from the weight of the thing--is it only has a remote to control it. If the wire or switch goes it's over. No switch on the winch itself. Other than that it has paid for itself many times over already and I just got the thing in September.
Thomas 8020, Stihl 039, Stihl 036, Homelite Super EZ, Case 385, Team of Drafts
Chuck White
I would think that the winch could be opened up and a switch be hardwired in.
Gideon, most of the affordable winches you can find are designed for towing not dead lifts, and are but toys for real work. Locate a business in your area that operates tow trucks they always have used winches under the bench. I had one given to me, burned out electric motor, I substituted a hydraulic motor. That made an awesome winch with no duty cycle. On that subject cheap electric winches are designed for intermittent use and are easy to overheat with constant use. Frank C.
Andy White
Guideon70,
Mount for the winch on my arch lets me pull instead of lifting. Just install a pulley and turn the cable vertical. Mine is a Warn 3500# atv winch. It has lifted many loads nearing 3000# with no ill effects. Use of the snatch block will ease the load, but slow down the process, but I get it done.
There are several ways to do this safely!! Be carefull.      Andy
Learning by day, aching by night, but loving every minute of it!! Running HM126 Woodland Mill, Stihl MS290, Homemade Log Arch, JD 5103/FEL and complete woodshop of American Delta tools.
Gideon_70
Oh, I LOVE this one!  I think I might be able to modify mine to do that.
Gideon_70
Hey, I got some great ideas and want to thank everyone!  I'm going to have to modify the arch a little, but I think this will work out great!
