Stihl 031 Misfire sound?
Started by gravydude, December 06, 2014, 07:59:19 PM
gravydude
I've been working on my 031AV for weeks now. The unit didn't want to start at all. After checking the gaps on the coil, points and installing a new carb rebuild kit, the saw finally runs!! At least for about five minutes.
The saw runs great until under a load. I can rev this saw up with ease, but when I put it on a log, it loses power and sounds like the plug is misfiring.
Any suggestions?
Don't know if it could be bad coil, condenser, or something else.
Cornishman
Plug misfiring. You did ask ! Presumably you have changed it.
Seriously though it could be anything. Weak spark prompted by some electrical fault such as a faulty coil that gets worse as the saw warms up or under load. Mixture wrong. My favourite would be a leak in the impulse tube  and you are running short of fuel.
Fuel pipe(no holes) and filter OK?
Compression OK?
jerry sundberg
I've found that crankshaft seals will do this.
Farmall  man
